Traction issues
   / Traction issues
Waiting is not an option... The house will ship when the house ships, and the piles of gravel are where the house will need to go. It HAS to be spread within the next week. I think I am going to give the backhoe a try tomorrow.
This stuff is always going to be to thick for a FEL, or backbox. Its crushed gravel with the fines and the larger base gravel all mixed together and wet. It has the consistency of very heavy clay... It being wet actually helps it break apart easier than it did when the last pile I spread was dry. The bobcat then had no problem with it.
The gravel is also going onto virgin ground so it shouldn't sink in to much. I know ill get some major ruts when the heavy equipment gets here, but that's going to happen no matter what.
   / Traction issues #22
If the pile is hard,use the backhoe to loosen it up.
Then use the loader to shove the gravel around.
Don't get down in the mud, stay up on the gravel while you shove it around with the loader.
   / Traction issues
This was broken up by a backhoe yesterday and loaded and dumped yesterday... I cannot possibly make it any looser than it is. The ability to shove it around with the loader is minimal when I can only get traction on existing compacted base.
   / Traction issues #24
Sounds like to save your anxiety it's worth hiring a tracked skid steer. Don't expect too awful much, as that froze/thawed goop will be under it. #2 for staying away from the block foundation.
Cant tell if that's a frost wall or cellar. If cellar, I trust you have porous material around the wall, and dampproofing on it? If not I would dig around your wall and seal it right, then get some stone or gravel for backfill. If its a damp site you'll kick yourself forever otherwise. 40 year contractor advice. I know, last thing you want to hear.
Jim
   / Traction issues
Its not a damp site normal conditions. When I had the gravel delivered I thought I had 3-5 weeks to get it spread. I got an email that said the house was finished and they would be delivering it (modular so two 15x68 halves) possibly next week. The piles of gravel are blocking access to where they need to place the two halves to allow the crane to set up right where the gravel is going to be spread.
That is the foundation for the house, its on a crawspace. Not sure what you guys mean by stay away from it.... the gravel will be going right up to it.
   / Traction issues #26
Well, be careful you don't also put a tractor in the way of the house when it gets mired in the mud! ;) But be sure to share some pictures of the mess either way.
We have had relentless rain for months here, and all the building sites around me are a mess. I barely made it in and out of one a couple weeks ago when moving a couple buckets of material.
   / Traction issues
and I don't expect to much... just need to cover the mud. I am actually hoping all the construction traffic will press it down into the dirt, as this will be the base for another 3 inch's of crushed gravel to sit on for the top coat which I will level out after the construction is complete.
   / Traction issues
I knew I should have ordered the Pirahna tooth bar a few months ago when I had the scratch and was thinking about it... Since then we have purchased all new furniture for the new house, bout the material to build a table, 8 chairs, a coffee table, and a murphy bed, and I still have to buy decking framework and fencing.
   / Traction issues
At least if I have the backhoe attached I will be able to use that to get unstuck.
   / Traction issues #30
When you bring a 70 ton crane in you you are not going to worry about your gravel. They will set mats out and run their out riggers on top of these. They will set the crane first and bring the boxes in next. Semi and trailer will sink in the mud also. You might hope for freezing weather. If the ground is not frozen call the builders and have them check out the site. As a crane operator this was a easy day- drive out to the site and come back to the shop. You know who pays for the travel time and it is not cheap.
2010 BMW 328i (A56859)
2025 GPS 11.5ft Utility Trailer (A56859)
2025 GPS 11.5ft...
CAT 777B ARTICULATED DUMP TRUCK (A58214)
CAT 777B...
Kubota K7874 18in Digging Tooth Bucket Excavator Attachment (A55973)
Kubota K7874 18in...
Brown Metal Roof Panels (A55758)
Brown Metal Roof...
PALLET BOX OF MISC (A58374)
PALLET BOX OF MISC...
