Snow Traction in snow
   / Traction in snow #1
Boondox
Elite Member
Craftsbury Common, Vermont
Deere 4044R cab, Kubota KX-121-3S
My present tractor is so light (1400#) and my hill so steep (22% grade) that I have to use chains on all four corners. The tractors on my wish list (JD4300, Kubota L3010/3410) are easily twice that weight and have a lot more ground-sticking power.
I'd like to hear whether those of you with beefy tractors have to use chains on slopes.
Pete in Vermont
   / Traction in snow #2
Boondox,
I sure do. The dealer said no go for chains on the my tractor because there wasn't enough room. I just widened the tires and put them on anyway. I have some hills here and on a hill in snow and ice, even with 4wd mine is worthless without chains for pushing snow.
   / Traction in snow #3
Pete,
I'm a firm believer when it comes to running chains on the rear.....all year round for this cat.
Tire chains = good traction.
Thomas..NH /w3tcompact/icons/wink.gif
   / Traction in snow #5
I run chains on the fronts all winter, and on the rears when the ice gets real bad. I have a Cub Cadet 7260 with all 4 R4's loaded. Clearance isn't a problem. The traction difference chains make is incredible.
Corm
2003 Honda Element (A50324)
2003 Honda Element...
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A52128)
John Deere 6105E...
1995 KOMATSU WA320-1 WHEEL LOADER (A51242)
1995 KOMATSU...
2023 BANDIT SG-75 STUMP GRINDER (A51242)
2023 BANDIT SG-75...
2016 KUBOTA RTV-X900 UTV (A51242)
2016 KUBOTA...
2020 VOLVO VNL64T740 TANDEM AXLE MID ROOF (A51222)
2020 VOLVO...
