traction belt ?
/ traction belt ? #1
greycat
JD LT133
How do I adjust NEW traction belt on a JD 133 ? Tractor will not pull a hill in my yard, except in 1st gear.
Thanks, greycat :(
/ traction belt ? #2
the traction belt is self adjusting, be sure that the two pulley tensioner setup is working free and allowing the belt to tighten. You did get it back on all pulleys?
/ traction belt ?
Hi Joecdeere, Thanks for the reply. I dropped the mower deck and I'm guessing that the tensioner is the spring on the left side and heavy duty spring on the right side that move when the clutch is depressed ??
Should I spray with WD 40 ?? Also do you have a diagram that shows the tensioner ?
thanks, greycat
/ traction belt ? #4
if it's an LT133 the highlighted part is what moves when the pedal is pushed and the assy moving with the belt weaving through the two pulleys is what keeps it tight.
/ traction belt ?
Hi Joecdeere
Thanks for the reply, sorry I took so look to reply. I found an adjustable pulley in the 3 pulley tensioner cluster. My tractor nows goes up hill in any gear !!
Thanks sgain for your help
greycat
2019 CATERPILLAR CP54B PADFOOT ROLLER (A62129)
2019 CATERPILLAR...
Rake Mini Excavator Attachment (A61572)
Rake Mini...
CUSHMAN REFRESHER GAS GOLF CART (A63276)
CUSHMAN REFRESHER...
2022 CATERPILLAR 299D3 SKID STEER (A62129)
2022 CATERPILLAR...
2017 Cadillac Federal 70 IN Limo - 30,529 Miles w Premium Coachwork by Federal (A63688)
2017 Cadillac...
2015 John Deere 310SL 4x4 Extendahoe Loader Backhoe (A61572)
2015 John Deere...
