Track conversion for Skid Steers
/ Track conversion for Skid Steers #1
Coyote
North Carolina
Yanmar 2000B & Skat Trak 1300D skid steer
Check out this web site. It is a track conversion that bolts onto any SS, right to the hub. Don't know the price, probably expensive but a cool engineering idea. Just an FYI to this group!
http://www.loegering.com/VTS.htm
/ Track conversion for Skid Steers #2
The full-size unit is around 15k, but that may come down (the VTS system is about a year old).
The smaller unit is around 12k. Not sure what the unit for 54"+ wheelbases will run...
/ Track conversion for Skid Steers #3
Got some recent prices from my local sales rep and they are:
12” $11,500, 15” 12,000, 18” $15,138 -$16,500 retail, plus freight.
/ Track conversion for Skid Steers #4
VTS bolt on tracks seem high priced when you could just trade in your beat up skid steer for a true rubber track loader, something like an ASV, that is built from the ground up to be on tracks.
/ Track conversion for Skid Steers #5
The value of the bolt on tracks is that you can un-bolt them and put the wheels back on when required. It takes about an hour or two to complete the swap. There's a video at their website showing the installation process.
/ Track conversion for Skid Steers #6
We sell allot of those units here in DFW. They outlast our CAT rubber tracks by 3 times or more. They are expensive at 15K but they are tough and add front suspension, metal undercarriage to a wheeled SS.
/ Track conversion for Skid Steers #7
I have a CAT 287 that I have 2100 hours on the original tracks and undercarriage. If you take care of it, it last! You just cant counter rotate all the time and you must try and keep the tracks cleaned out.
Do you have to replace the drive sprocket on the VTS bolt on tracks with each new set of tracks? If you can get 3 times the life I have got out of my cat MTL (6300 hours) I would certainly switch to the bolt of tracks and gladly sacrifice my flotation and comfortable ride for that kind of life.
/ Track conversion for Skid Steers #8
We have never had to replace any VTS undercarriage components for wear. We have had some isolated bearing failures on a certain customers machine but no others to speak of. You must be using the 287 as it was intended, our MTL customers rarely get that life out of a set of belts. They do understand they are improperly using the tractor but are glad to pay for new belts to have the performance of the machine. The front axle of the VTS tracks is suspended on a torsion assembly similar to the CAT MTL loaders so there is some suspension. The track is also steel belted instead of the cloth belt on the AVS undercarriage which is really the main difference in the strength of the belts.
/ Track conversion for Skid Steers #9
Well sell a fair amount of VTS tracks as well, its about the same price to take a new wheeled machine and add the VTS tracsks than it is to just buy a tracked loader. As was said, it gives you the flexibility to change back to wheels when you need it. Tracks are not always the best system.
/ Track conversion for Skid Steers #11
Is that the machine that is over 100 hp? What kind of work are you going to do with it?
/ Track conversion for Skid Steers #12
Be very weary of the VTS system. There is no replacement for a dedicated planetary outdrive. This system is viewed as a "attachment" and will not be covered under the units parent manufactuers warranty.
Virginia Dealer
/ Track conversion for Skid Steers #13
The VTS has been in the market for over 2 years now and has various sizes ranging in price to cover a wide range of machines. The price starts at $11,500. The system has an impeccable reputation for being a valid attachment and although select manufacturer's warranties may be voided with installation, some manufacturers do not take that stance. If that is a concern to the user, Loegering provides a service contract that can be purchased to cover machine failures in the event that the manufacturer's warranty will not cover failure.
Most, if not all, track machines are going for far more than $11,500 - $15,000 new and have the following:
-Higher depreciation than your skid steer loader at trade in
-Depending on Mfg, may or may not have suspension
-Higher operating costs
-Lack the versatility of taking the track on and off when needed
-Down time when it needs service
-Pay premium to purchase track every time you buy a new track machine, can not bring undercarriage to new machine
/ Track conversion for Skid Steers #14
I have had my VTS tracks since Dec. 2004. I was one of the first to get a set. I was pretty skeptical getting something that wasn't on the market for a while. I did a lot of homework on the system and found Loegering very helpful. They gave me access to the people that did the testing and I got a lot of valuable information before the purchase.
I use them on a S250 Bobcat and I am very happy with them. They paid for themselves in less than one year (I calculate this by the jobs I got that I wouldn't have if I didn't have them). I have various experience using MTLs in the past. I have used Cat 287, Bobcat T300 and T190, and numerous ASVs.
My interest in the VTS came about when I identified jobs that I could get or do better with a track system, but couldn't justify a dedicated machine. I previously used a set of grouser steel over the tire tracks which added a significant capability to a skid steer but had some drawbacks. The VTS system doubled the capability that the over the tire steel tracks did but with none of the drawbacks.
The things I really like about them are:
More versatility than a dedicated machine
They work great with my 2 speed
On and off doesn't take much longer than steel over the tire tracks
The suspension is great
They are wearing very well
Absolutely no problems (I use my equipment hard but I don't abuse it and I am good with my maintenance.
They are the easiest to clean of all the MTLs I have used in the past.
The design is very open and therefore very easy to clean. Hardly any spots to trap mud. The track tension is very easy to adjust. I have found, though, that not much adjustment is needed. I attribute this to the very large drive sprocket which engages more teeth of the track than any other steel imbedded drive system in MTLs. I think this spreads out the force on the track and reduces the tendency to stretch the track.
Basically the VTS system gave me the advantage of another machine and paid for itself in less than a year. To me that makes good business sense.
I would be happy to answer any questions you may have about this system.
/ Track conversion for Skid Steers #15
Now on the VTS webpage you will find footage of the Construction & Landscape Expo. Loegering delivered 13 skid steers equipped with VTS for demonstration. The VTS - Versatile Track System® performed flawlessly in both dry and wet conditions. The show was 3 days long and blessed with 4.5 inches of rain in 24 hrs. A big THANK YOU to all that attended!
Feel free to share this link with friends!
Website: Loegering Mfg. Inc. / Products
Link title: 2006 Construction and Landscape EXPO NEW!
- Loegering Mfg.
/ Track conversion for Skid Steers #16
I will sum up my experiuence with a copy of the e-mail I recently sent Loegering.
I for one am quite happy and impressed by the system.
To: Logering manufacturing and its employees.
I am one of many skid steer loader owners who made a near fatal mistake when purchasing my loader.
I bought a Bobcat S205 rubber tire machine depending on the “power of 4 wheel drive” to get the jobs done.
Well my friends let me tell you a thing or two about 4 wheel drive and rubber tire machines. It means very little to almost nothing in low traction conditions.
If I had even a slight sprinkling of rain on a jobsite I was out of business until it dried up. Four wheel drive became 4 wheels stuck.
I also found that traversing inclines and declines was like walking on eggshells. My advice with rubber tire machines is to stay on near flat surfaces with dry high traction conditions.
I spent a lot of time looking at over the tire systems and different tires with more aggressive patterns but could not convince myself that either of these were acceptable or long term solutions.
Enter Logering manufacturing.
I looked at the VTS system and was immediately interested. Not only did it meet my needs it also saved me on what an equally capable track machine would cost.
The design has several things I liked.
Open design for ease of maintenance and cleanup.
Heavy duty mechanical style tensioning system with no grease seals to fail due to dirt.
Aggressive track design.
Bolt on installation.
Extended surface contact to improve machine stability.
Since I have purchased this system my life has changed.
Jobs I would not have even quoted before are a snap to complete.
Lifting capability due to the extended wheelbase is astonishing.
Traction even in mud is fantastic.
Pushing power is easily tripled compared to the tire configuration.
I use my machine for grading to prepare for landscape installation, log loading for tree removal, delivery of boulders for yard decoration, concrete demolition, and many other smaller tasks.
I can now even dig where digging was a challenge even in soft soils before the tracks were installed.
In short I’d like to extend my appreciation to the folks at logering for doing a fantastic job in designing a solution for those of us who had rubber tire machines and needed tracks that are reliable, sturdy, and easy to maintain. I could not be happier with my purchase and I also could not be more satisfied with Dave Gibson and Tim Chupp of Lashley Tractor sales for the professional service in acquiring and installing the system and their time spent with me during the decision process.
A special thank you to Greg Rosten who endured my many calls asking questions about the system and in answering my e-mails immediately. I do a lot of my communication via e-mail and I cannot tell you how many of my inquiries to other companies seem to just vanish into thin air never to be answered or took weeks for a reply.
With sincere thanks,
Calvin S Johnson.
/ Track conversion for Skid Steers #17
was in land-clearing for years with d 8 cat-sold cat but needed tracks for my case 420 to move 400 truckloads while cleaning out my fishpond.a set of tracks from righttrack-edmonton cost me less than $4000.00 against $20000.00 to $30000.00 added on a new machine.i moved another 70 truckloads for topsoil this spring.also took out 24 fairly big spruce trees and did some more work in a slough.you get 3 to 5 times the traction with tracks over tire machine plus you dont get bogged down in wet areas.overall tracks are a very cheap investment.the ones i got are repairable and low maintainence.need any info contact me at 780-352-8441
/ Track conversion for Skid Steers #19
I know serval guys that ran the vts system each one of them had tons of problems with the bearings going out all the time dealer said they we're running tracks to tight but they couldn't keep the tracks on unless they we're tight
/ Track conversion for Skid Steers #20
Cat, I've never seen the VTS system in person, but it looks like it drives only off of the rear. Maybe I'm missing something, but it seems like it would be pretty tough on the rear chain.
1994 Chevrolet C70 Kodiak 18FT Box Truck (A61573)
1994 Chevrolet C70...
2014 Bobcat T650 (A60462)
2014 Bobcat T650...
2015 Peterbilt 367 T/A Wet Kit Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 367...
International S1900 (A63118)
International...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A56438)
Kuhns AE10 Small...
Club Car Golf Cart (A64047)
Club Car Golf Cart...
