Trac Vac Hose
   / Trac Vac Hose #1
ronjhall
Super Star Member
SW Oakland County Michigan
2, Kubota B2910 HST
I have purchased a Trac Vac for my JD lawnmower. I bought this unit used and need to extend the 6” hose 4’. Anyone knows of a source for this hose. All the dealers around my area want $10.00 foot for the hose. /forums/images/graemlins/crazy.gif
I’m in need of 8 feet or an extension for the 4 foot I already have. An extension will require a coupler. But since I need to support the hose this will not be a problem. I have inculded a picture of the current hose.
Thanks for any help.
   / Trac Vac Hose #2
Kinda looks like an RV hose. Have any pressue cleaning places near you?
   / Trac Vac Hose #3
Kinda looks like the corrugated drain pipe stuff. If that's the right diameter, it sure would be cheap.
Chuck
   / Trac Vac Hose #4
I have a source for the hose, but it's at home and I'm at work. Not sure of the price. The hose I have used/seen in this type of an application is generally smooth (on the inside) relative to general purpose hose of the same diameter. I think it allows better flow and lessens the chance that grass and debris (especially wet) will build up.
I will either find the hardcopy or a website at home this weekend.
Bob
   / Trac Vac Hose #5
The hose used on Trac-Vacs is corregated on the inside as well as outside. Some Trac-Vacs use 6 inch hose but the the more powerful units use 8 inch. The going rate is around $10 per foot for the 8 inch hose. I don't think you'll find it cheaper anywhere unless someone is going out of business. I find most dealers don't stock hose like this. They special order it to the length you need from a distributor for Trac-Vac products. When I have needed to couple 2 sections of hose as you indicate you will do, I use a section of 8 inch black stovepipe and 2 radiator hose clamps.
Sorry to have to bring bad news about the price of the hose.
Jack
   / Trac Vac Hose
The hose has a metal or plastic wire that helps to support the hose. The picture does not show how heavy the hose is very well. I found a product called Sprialflex. It’s $4.16 a foot. I’ll have to check on the shipping cost. Click Here It is the best deal I have found so far. I don’t know if it will work with Trac Vac though.
   / Trac Vac Hose
Jack
You didn’t bring all bad news. /forums/images/graemlins/smile.gif Using a section of heavy gauge stove pipe may be the best way to solve the problem. I’ll try looking for some.
   / Trac Vac Hose #8
Ron,
I bought a length of 6" hose at Weingartz in Farmington Hills a couple of years ago and it was $8-something a foot back then...
   / Trac Vac Hose #9
Ron,
That looks like what is used for dust collectors. Go to Amazon.com and search for JW1036. Unfortunately, it looks like the only way to buy it is in 10' lengths, so it ends up being more than 4' that you can get locally. However, if you were going to replace all 8' so you don't have connectors, it might work. You could also try:
Grizzly
or
Internation Hose Supply
This place has stuff specifically designed for leaf collection (their "T-7" hose) that's less than 60.00 for 10'. Anyway, good luck.
Kevin
   / Trac Vac Hose #10
Institutional/commercial laundry equipment (washers) use hoses similar to that for drains. The place I am familar with purchased theirs from a plumbing supply house, not sure of the cost however... /forums/images/graemlins/confused.gif
2016 John Deere Gator 825i 4x4 Utility Cart (A53421)
2016 John Deere...
2023 Club Car Carryall 700 Utility Cart (A51691)
2023 Club Car...
2020 KUBOTA RTV...
1987 Ravens 45 ft. T/A Float Trailer (A53117)
1987 Ravens 45 ft...
2013 ISUZU NPR STAKE BODY TRUCK (A54313)
2013 ISUZU NPR...
2023 DOOSAN DL220-7 WHEEL LOADER (A52706)
2023 DOOSAN...
