Trac-Vac hooking up to a John Deere 1026
   / Trac-Vac hooking up to a John Deere 1026 #1
denverdave66
Missouri
2012 John Deere 1016, FEL, 60"MMM
I have a Model 880 trac-vac and had it hooked up to a john deere Lx277. I just bought a SCUT JD 1026. What modifications will I have to do to connect it to the back of my tractor? I know I will have to buy a different attachment for the deck.
   / Trac-Vac hooking up to a John Deere 1026 #2
There are about three issues you will run into. The first is changing the mount to a 3 pth system. The second is that your 8 inch hose between the vacuum and the mower deck is now going to be too short. The third is the head that attaches to your deck needs to be modified.
To cure problem number two. I sectioned the deck attaching head. It had to be both taller, and longer. I did this on a Kabota B series tractor. It took two days, and about 5 hours of cutting a welding. Have some CAD Drawings of the parts changed. Still a doable project.
   / Trac-Vac hooking up to a John Deere 1026 #3
At one point, I had one on my BX2200 and made no mods. I just used the drawbar instead of the three-point. The three-point would get in the way if not chained up though.
   / Trac-Vac hooking up to a John Deere 1026 #4
I don't see the huge problem. Modify the boot on the mmm and possibly need a longer flex hose. Both tractors pull the trac vac from the hitch as the unit has its own engine for power. Seems pretty straight forward. Should operate just fine.
2026 Anvil Trailer (A56859)
2026 Anvil Trailer...
2019 Ford F550 Chassis (A55973)
2019 Ford F550...
Hose Reel (A55758)
Hose Reel (A55758)
New Holland TS6.120 Power Shuttle 4WD 120HP Agricultural Tractor (A56857)
New Holland...
ST205/75R15 Trailer Tires (A55788)
ST205/75R15...
Hyundai HL 960 Wheel Loader (A56857)
Hyundai HL 960...
