TPH implement pin settings...
   / TPH implement pin settings... #1
KrisHansen
Vermont
New Holland TC33d
Hey all!!
with my Woods rake, the arms on the TPH are set very wide, so wide in fact, that the tire chains have been known to hook on the lower part of the vertical arm (no pics handy, if you can belive that!).. What I was thinking, flip the pins from the outside to the inside of the frame, which should allow the TPH arms to be narrower.. Is there any particular reason why some implements are set with the pins on the 'inside', vs. 'outside' of the frame? My woods blower has them on teh inside, for example.
   / TPH implement pin settings... #2
I find it is easier to get them on & off if they are on the outside.
Are your tires "dished out" - ie on the widest setting? That can make a big difference regarding clearance...
   / TPH implement pin settings... #3
The wider the pins are, the better they are at preventing lateral movement (i.e "jackknifing".) With that limitation in mind, you could have the pins facing inward, but mounted so that they are the correct spacing for the Category 3PH you have (for example, Cat I is 26 inches.)
Tires are set at their widest setting.. I think I may just try it, for kicks... Thanks!
   / TPH implement pin settings... #5
KrisHansen
On the pin where your 3PH lift arm connects to the tractor, are there spacers?
I have a couple implements that have the same issue (rub on tires). I just move the spacers to the outside which corrects the issue.
Brian
   / TPH implement pin settings... #6
</font><font color="blue" class="small">( Tires are set at their widest setting.. I think I may just try it, for kicks... Thanks! )</font>
Should work fine. Pins pointed outward are a bit easier to get the implement on & off, but otherwise if you have clearence the pins inmward should be fine. Perhaps this is a cat 2 implement with cat 1 pins on it? Are the bolt parts of the pins rather thick to fill a big hole in the frame?
--->Paul
Thanks all,
I swapped the pins over, seems to work fine.. The eyes on the ends are aimed sharply inward now, but nothing is binding...
   / TPH implement pin settings... #8
I have a Woods back blade and a Woods blower, just like your setup only smaller on a TC24D. I wondered the same the thing and got thinking why they might be set up the way they are. One thing that came to mind is that the blower is designed to be pushed with the 3PH arms, the blade pulled. The pins to the inside on the blower allow any outward pressure from the arms (since they are already spread to a degree) to push against the frame of the blower rather than the lynch pins. The opposite is true on implements that are pulled such as the back blade - any inward pressure pushes against the frame. The lynch pins are strong, but if they are loose or even have fallen out, at least the design would tend to keep it hooked up.
Probably thinking too much and it might not really matter, but the tractor doesn't talk to me and I have to keep my mind busy doing something while I'm out there /forums/images/graemlins/tongue.gif
Brad
Brad,
I think you are correct. I'll have to make a point to check the conntections often. This is only for times when I have the chains on, I generally don't use the rake much with the chains, but sometimes.. Thanks for your imput!
3pt Roller (A50121)
3pt Roller (A50121)
2012 INTERNATIONAL WORKSTAR 7500 (A52472)
2012 INTERNATIONAL...
(30) 24-A Macro Bins (A50121)
(30) 24-A Macro...
2011 TROXELL 130BBL (A52472)
2011 TROXELL...
2008 GMC C7500 Altec LRV55 55ft Forestry Chipper Bucket Truck (A50323)
2008 GMC C7500...
2013 Infiniti JX35 AWD SUV (A50324)
2013 Infiniti JX35...
