diesel lover
Platinum Member
- Joined
- Dec 21, 2013
- Messages
- 643
- Location
- whites town indiana
- Tractor
- Ferg. To 20, 1956 Massey F. MF 25 diesel, Ferg. 40, 1944 John D. A, 1965 cockshutt 40,
a radiator was recently changed on this vehicle. I cannot find any leaks or see how low the coolant is but there is no coolant available in the recovery tank of the car. I found no leaks but there could be a leak of course.Many of the new coolants are labeled safe for all makes and models. The real question is why is it low? Chris
I wish I knew. It is not wise to mix coolants if you don't know what's in there. There radiator is sealed so I can't tell what was put back into the systems.Who changed the radiator? Do they happen to remember if it was orange or green?
I drive a Toyota(different model) and a lot of other Toyota owners suggest only using the coolant available at the dealer. That is what I have done in the past ...
At my last job we used fleet gaurd universal coolant and it actually would work good with all makes all models. Many good factors about that coolant. Before mixing any coolant a very thorough flush is needed.Guys I know say to use only Toyota coolant. $24 or so a gallon for pre-mix and you should know if you have red or green/yellow and get the same kind. While I was buying some at the dealer recently, there was a fellow there getting a new radiator and water pump. He said he used a different coolant for the last change and his troubles started after that. You would think there would be an aftermarket coolant that works but there must be something more to it. I'm staying with Toyota coolant unless someone can convince me otherwise.
Thanks Dave completely true!! The long and short of it is sealed radiators, new low drag water pumps, and systems that are hard to bleed without jacking the front end in the air. Ouch
I don't understand this jacking the car up in the front end. I never did this. What does it do and why do you need to do it?
Yeah my girlfriends car already had green coolant in it when I met her, we had it flushed when he water pump was changed and all we use is all makes all models. The VW coolant is 20 to 30$ per gallon!!! You void the VW warranty if you don't use it .VWs use a completely different coolant and if you top up with "regular" glycol-type anti-freeze, it will form a clot as the two types don't play. This clot/blob of gel will eventually clog up the heater core and/or radiator. So I stick with the dealer brands for the vehicles. On my BX, I used pre-mixed 50/50 when I change the coolant.
100% true. When air is allowed in the cooling system with dexcool the results are hazardous!!Same issue with GM's Dexcool. I see so many GMs at my buddy's shop with this problem, that I'm beginning to suspect that you don't even need to mix anything with Dexcool to encounter this problem. I think one of the issues with this class of coolant is that if you have even a slight air leak (loose hose clamp) then the coolant will sludge up. Rgds, D.
