Toyota Prius
Status
Not open for further replies.
   / Toyota Prius #151
I am bored... in a Prius. :laughing: They are boring to drive. No guts.
Years back I drove a boring 1962 Ford Falcon with an underpowered four cylinder. I learned to turn the radio up to make it more exciting and it worked. Maybe turn the radio up in a Prius?
   / Toyota Prius #152
I'm not knocking them at all. I love both the Prius and VW TDI. I'm just pointing out that they are not the lowest cost solution.
IT, you may be right about a used VW. I need to run the numbers, it's just that I keep coming up against a timing belt change every 1.5 - 3 years which is pricey and kills overall fuel savings. VW should've run timing gears or pushrods IMO.
Prius owners I have a question which could only be answered by a seasoned owner. My 125 mile commute goes like this. Load kids into car and drive to front gate, sit there for 10 minutes with the radio on waiting for the school bus. Then onto the highway for roughly 60 miles at highway speeds 75mph (now the speed limit) with the air conditioner near full blast. The last 5 miles is city traffic stop and go but averages 40 mph. My question is, with the highway speeds at 75, without much battery re-generative braking, what would you estimate the mileage to be? So in effect, I'm NOT a hypermiler.
I know you are on the right track buying cheaper gas cars that get less mileage.
Look at it this way. If your car currently gets 30MPG on the highway, and gas costs $3.25 per gallon and you drive 30K per year, you're going to spend $3250.00.
If you get a car that gets 45MPG, and gas costs $3.25 per gallon and you drive 30K per year, you're going to spend $2166.00.
That's a $1084 savings in fuel costs, but only if you stick with a gas car.
If you switch from a 30MPG gasser to a 45MPG diesel, the average price of diesel is over $3.80.
30000/45*3.80=$2533.00
That's only a $717.00 savings per year.
Its not worth the cost to trade up to a more fuel efficient car once you figure the energy savings payback.
And while you'll find a ton of people that say their VW's are great, you will still see the horror stories of folks that lost a timing belt and face a multi-thousand dollar engine rebuild.
Also, no one mentions the $500.00+ service required at 40K, which is on you, as the warranty runs out at 30K.
Buy 3-4 year old Impalas that get 30MPG hwy and drive them into the ground. They are big, roomy, hold 4 sets of golf clubs in the trunk while still seating 5, or even 6 if you find one with a bench seat.
   / Toyota Prius
Here's another Prius question...What about repairs and service? Being a hybrid, my guess is that the typical garage couldn't do repairs to the electric engine or the batteries, so you'd have to take it back to Toyota, right? That sure would increase costs. What do you Prius owners do?
   / Toyota Prius #155
Nothing. They don't break. Oh wait, I did have to take mine in one time so they could update the software.
As for the car being boring to drive, maybe, but that's what I like. I stopped worrying about how I look driving a car or having one that is exciting to drive sometime back in my twenties.
If my Prius did break, the last place I would want to take it to is a typical garage, or any of my vehicles for that matter. Cars now-a-days are all computerized and highly technical. Elmer and his crew can stick to the old Buicks and Impalas that some here prefer.
BTW, the no guts comment is entirely off the mark. The electric motor provides a huge amount of torque when accelerating as any Hybrid owner can tell you. Another misconception.
The only service it needs is the standard oil change. Jiffy Lube does mine.
   / Toyota Prius #156
Very little service needs to be done. No belts to change, timing or otherwise. Long intervals between oil changes. The Hybrid Battery needs no maintenence till it is changed. My dealer has never changed one. The 12 volt auxillary battery is about the same size as a motorcycle battery. It is a plug and play 15 minute job anyway. Doing your own oil changes will not void the warrantee. Brakes are only used in hard fast stops like in a screeching stop to avoid hitting something. The regenerative brake system is what slows the car. Theretically the brakes never need to be changed.
Go talk to a dealer they will show you everything.
2013 Toyota Prius Manufacturer Service Schedule and History - DriverSide.com
Hybrid Taxicabs - HybridCars.com
Diesel vs Hybrid - Cars Bikes Trucks - Malaysia Cars Bikes Trucks One Stop Automotive | Cars Bikes Trucks - Malaysia Cars Bikes Trucks One Stop Automotive
   / Toyota Prius #157
I remember that a Prius was lightly rear ended in a fender bender in front of where I work. The fire dept came and sprayed a foam all over the Prius. I think a bit of common sense should of prevailed and realized is was a slight fender bender and there was no need to spray the car down.
   / Toyota Prius #158
EV's are a real shock hazard to fire fighters. We've had some training sessions about this issue, especially in extraction situations. Unfortunately, we don't have a junk Prius or similar to cut up for training.
   / Toyota Prius #159
I haven't seen a single Prius commercial extolling their hauling capacity or service in commercial delivery.
Status
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A55787)
2025 Kivel Forks...
2011 Ford F-550 ETI ETCMH37IH 37ft. Insulated Material Handling Bucket Truck (A55973)
2011 Ford F-550...
NEW Wolverine Skid Steer Trencher (A59000)
NEW Wolverine Skid...
2007 Reitnouer 40 Ton T/A Heavy Haul Flatbed Trailer (A55973)
2007 Reitnouer 40...
SAND ALL SANDBLAST POT & RESPIRATOR (A52708)
SAND ALL SANDBLAST...
LOT: (2) 2-Wheel Dollies, Roller Stand, (3) Screw Levelers (A59076)
LOT: (2) 2-Wheel...
