Towner Equipment Harrow Spring Tooth Cultivator
   / Towner Equipment Harrow Spring Tooth Cultivator #1
edge08
Hello, I bought a Towner 3 row spring tooth a couple of years ago in pretty good shape as a package deal with a John Deere LX5 mower. It mates very well to my New Holland TC 55 for doing clean up work scratching mettle and garbage out of the weeds. I have one broken tooth and asked about parts at tractor supply and got the I'm with stupid look. I just rearranged the teeth so they are all in one row on the back bar to do a better job raking. I would like to see about adding a few teeth to this implement but it may be cost prohibitive for what I'm doing. This still has yellow paint and the name visible. I didn't think it looked very old but I'm having a real hard time finding any references to towner on the internet or parts for them. I'm guessing from what I read that Towner equipment in Santa Ana California must have gone out of business years ago. Can someone give me a bit more information about what I have and where I might find replacment teeth that are compatible. This unit is a 3 point hook up type and about 6 to 7 feet wide. Each tooth is bolted with one 2.5 inch, 5/8 wide bolt and a slide through bracket onto an L shaped bar. It sticks out maybe 6 inches to a foot on each side of my TC55. Is there a current manufacturer using this type of tooth that is a direct replacement or do I need to hunt for another one to canibalize for parts? My dad had a similar spring tooth but it is heavier with square tube brackets so the springs don't match up. I would appreciate any information or suggestions you might have regarding this implement.
   / Towner Equipment Harrow Spring Tooth Cultivator #2
YOu really need to post photos.
I have an old 6.5 ft wide Towner offset disc that I use on my 6-acre hayfield. I was able to get replacement pans (discs) from Agri-Supply. You might see if these folks can help.
UNUSED AGT YSRT14 STAND-ON SKID STEER (A51247)
UNUSED AGT YSRT14...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2008 Chevrolet Uplander LS Van (A51694)
2008 Chevrolet...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
(1) 12ft Tarter Gate (A51573)
(1) 12ft Tarter...
