towing unbaked
/ towing unbaked #1
machno
byfield qld
na
Hi every all im new to the site and a bit new to tractors I hav been living rural in byfield qld all my life but havnt had much to do with farming or tractors im looking for advice on buy a tractor to tow my boat 30ft noosa cat and launch at the ramp.I hav used a 75series cruiser to pull it across the yard but It really draged the arse on the ground which was expected I think the weight would be around 4 .5 ton max loaded I looked at a iseki Sx75 fwa for $12.000 but thought it may be to small.Thanks in advance seth
/ towing unbaked #2
I know this isn't answering your question, but are you asking about towing while not under the influence a particular herb? In that case, yes.
/ towing unbaked
Ha ha worth a try what hp ect would be suitable.come on mike shelby drives a fork lift up the street over there
/ towing unbaked #4
At the ramp ?
At the ramp you need some weight... how heavy is that Iseki ? On an average boat ramp i think your tow vehicle needs to be half of what the trailer weighs... I have calculated it last year for the military, about how big a trailer a wheel loader could pull onto the loading ramp of a landing craft. But i dont know what angle the average boat ramp is.
/ towing unbaked #5
HP doesn't really matter unless you need to pull it fast. An old 20hp 5000 pound tractor would pull it fine.
You need traction. You get traction from weight.
Bruce
/ towing unbaked #6
The Iseki Sx75 you are looking at should weigh almost 8000# (plus the loader, weight in the tires, cab if it has one, etc).
IMO that should be enough.
Aaron Z
2008 SUBARU LEGACY 4 DOOR SEDAN (A64280)
2008 SUBARU LEGACY...
Polaris Ranger 4x4 Gas Utility Cart (A66734)
Polaris Ranger 4x4...
2014 ALLMAND MAXI-HEAT PORTABLE HEATER / GENERATOR UNIT (A67714)
2014 ALLMAND...
2017 Ford F-350 Knapheide Service Truck (A66736)
2017 Ford F-350...
PORTA POTTY (A68842)
Lot of 2 ForeRunner 12-16.5N.H.S. Skid Steer Wheels and Tires (A64553)
Lot of 2...
Here are some similar links:
