Towing running gear with pickup
   / Towing running gear with pickup #21
Since some of you own these types of wagons, how is your experience with these backing up? I can back a car or cargo trailer with no problems, but the double pivot points on them farm wagons, forget backing any more then a few feet.
Dave
A 3 point trailer mover helps to move the connection point to the trailer further back from the rear axle which means that it moves more for a given movement of the front wheels.
We also will use the RTV (which has a front mount trailer hitch on it) to back a hay wagon in. I added a trailer hitch and front weight for the L3830, so we will be able to use that this summer and I imagine that will make it much easier as it weighs a lot more than the RTV and will have an easier time moving a loaded hay wagon.
Aaron Z
   / Towing running gear with pickup #22
Dave
It's practice. I've been doing it for years, only way to get good is to try it.
I can back one up as far as I to go and then turn and put it in a gateway or doorway. I can do it with a pickup, but trucks aren't as nice to back with.
I can also back a baler and wagon up to, but that takes a lot more time :)
Want more fun? I haul all my hay with tandem wagons, light plug at tail of first wagon, yes I do back it up, but try to avoid that. Did back it around a 90 degree turn last summer but took a few attempts.
CFG Industrial MX20R (A56469)
CFG Industrial...
UNUSED JCT 2 PRONG BALE SPEAR (A57193)
UNUSED JCT 2 PRONG...
UNUSED SDLANCH SDLD25 CRAWLER DUMPER (A57192)
UNUSED SDLANCH...
CASE IH MX220 MAGNUM TRACTOR (A57192)
CASE IH MX220...
40" EXCAVATOR HYD TILT BUCKET (A57192)
40" EXCAVATOR HYD...
UNUSED FUTURE HYD AUGER (A52706)
UNUSED FUTURE HYD...
