newbury
Super Star Member
- Joined
- Jan 8, 2009
- Messages
- 14,831
- Location
- From Vt, in Va, retiring to MS
- Tractor
- Kubota's - B7610, M4700
I know this has come up several times but the search function is broke and things change over time.
Situation/background -
I've an enclosed trailer, 7x16, rated at 10,100 lb GVWR and licensed in Mississippi, bought in 2019. Been using my F350 dually (rated to pull 12,000 lbs) w/ a 14K rated WD as a tow vehicle. Never had it loaded near 10K, usually 5 to 6 K at the max. So far all very legal.
The F350 is getting "long in the tooth" and I'd like to save it for when I need to haul that much weight and buy an F150 V8 for the rest of the time.
Have found several F150's with rated tow capacity of 9,300 lbs.
When I registered the trailer the clerk would not register it for LESS than 10,000 lbs. HAD to go by what the mfg rated it at.
I tried discussing it with the clerk, no way would they derate it. So I gave up.
Back when I was paying attention to the discussion of trailer laws here I read of one guy that got "busted" for pulling a trailer that was loaded well UNDER his trucks GVWR but the Virginia State Police required him to drop the trailer and get another truck to haul it away. The rule they told him was that the truck had to be rated for the trailer, even if the trailer was empty.
Has anybody else read or heard of this?
I can understand don't go over the GVWR or the tow rating for the truck. But if I'm pulling a 7K load in a 10K rated trailer with a 9.3K rated truck it should be legal.
I've tried calling and writing the DMV's - no results, just a "I'll get back to you" and they never do.
/edit - changed F150 truck rating
