Towing Kubota L3901 w/ BH-77 backhoe
   / Towing Kubota L3901 w/ BH-77 backhoe #1
Logan979
Kubota
Towing ? when towing a L3901 with BH-77 where do folk put their chains on Backhoe ? running front ones through FEL tube Thanks
   / Towing Kubota L3901 w/ BH-77 backhoe #2
Typically they go over the curled bucket. Going through the loader cross tube will work, but will be a HUGE pain to feed through. Just toss a chain over the top behind the bucket. If the chain is tight it can't go anywhere. If the chain isn't tight, you did it wrong & it's not serving any purpose anyway.
   / Towing Kubota L3901 w/ BH-77 backhoe #3
My B26TLB has a boom lock and a pin for swing lock. I use them when hauling them on my trailer. I am under the impression, if those are used I do not need to chain them in place. Also under the backhoe frame is a welded u shape that a run a chain through for tie down. The front has a grill protector that the chain goes over for tie down. The loader bucket gets a separate chain to tie down, usually across the top of the bucket. I do not curl the bucket. Jon
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A51692)
2012 Freightliner...
2022 John Deere 8R 310 MFWD Tractor (A53342)
2022 John Deere 8R...
2016 JOHN DEERE 3032E LOT NUMBER 97 (A53084)
2016 JOHN DEERE...
1999 24DTA pintle hitch trailer (A53472)
1999 24DTA pintle...
2015 FORD F-250XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250XL...
