Towed heavy yesterday
/ Towed heavy yesterday #1
bdog
Elite Member
Texas
John Deere 6130M
Normally we haul this load on the semi but decided to give the 17 F-450 a workout.
Trailer was a 32' PJ tandem dual with 15k axles, 17.5" tires, electric over hydraulic brakes.
Gross weight was just over 42,000 lb. It handled it great on the 425 mile trip. The only downside was I averaged about 4.5 MPG though having the cruise set on 75-80 most the way didn't help.
We went through some good sized hills, at least for Texas on I-10 between Junction and San Antonio and the worst it slowed down was to 60. Temps were 100 degrees and neither the truck or transmission never got hot. Pretty impressed with this truck.
/ Towed heavy yesterday #2
If you didn't take any pictures, then it didn't happen! (just kidding, lol....got any pictures of the load?)
David from jax
/ Towed heavy yesterday #3
So how does the pickup compare to the semi in gas mileage, power etc? Pics of both please!
/ Towed heavy yesterday #4
That's a good question.
I've dreamed for several years of having a tow rig that could haul 5 or 6 rockcrawlers. I'm pretty sure I could get in much cheaper by going big truck. But then you limit what other tasks it will perform. :confused3:
I have to tow it back either tomorrow or Sunday and will snap some pics then. The MPG's with the semi and truck are very similar. A little better with the semi actually. The semi hauls the same load but I also put my pickup on the trailer so the semi grosses about 65k.
The pickup has more power going up hills than the semi but is 23k pounds lighter. My Peterbilt has a small motor though a C-13 with around 430 HP.
Here is a picture of the Pete with the F-450 on the back of the trailer. The load I pulled with the F-450 is the stuff in front of the pickup in this picture.
Here is a closer pic of the truck. Shame it hasn't moved in over two months.
/ Towed heavy yesterday #9
Thanks for the pictures. That is quite a load. What do you do for a living that requires such equipment? Can you tell me more about the Peterbilt?
I am constantly amazed at what a truck like that can pull. We have the Ram 3500 in my avatar that we use to pull the tractor down to our farm and tow the travel trailer. The Ram was a big step up from what we had before but nothing at all like your Peterbilt. Since we started towing the travel trailer and tractor we have a lot more respect for those that drive semis.
My wife is from Ft. Worth and likes trucks almost as much as I do. We live in S.C. but I told the wife that I would move to Texas if we could move to Comanche. I am not getting much traction with that idea. You guys have real summer down there. I think that is her biggest problem with the idea.
/ Towed heavy yesterday #10
What did your trans, oil and water temp get to? I grossed 38k last week and the trans hovered around 235 on the highway cruising 65, water was 219-223. Seemed pretty warm to me. Trans would cool down in town which was the opposite of what I expected it to do
Brett
Brett
Highest water I saw was 223 and highest trans was 239 on the biggest hill. Mostly was around 220 & 233. While it seem warm to me as well it wasn't in the yellow or red.
We do oilfield work. Specifically seismic for oil exploration. We help them pick the locations to drill the wells.
The Peterbilt is a 2007 379 short hood with a Caterpillar C-13 engine and a 10 speed transmission. It is registered to gross 80,000 lbs. Its a good truck it has about 850,000 miles on it but the motor was rebuilt at around 700k. The C-13 is not one of Cat's best engines but it works for what I do.
Comanche is nice. I have driven through there many times.
/ Towed heavy yesterday #13
It's not what you do, but the toy's you need to do it that count! :D
Nice set up bdog.
/ Towed heavy yesterday #14
I had some coastal sprigged this March and they pulled in all with a F 450. If not for the number on it would have not realize it was a 450. Pulled am sure at least 30 maybe 40 foot trailer with good size New Holland tractor and the sprigger on the trailer and not sure but think a 3,000 pound roller towed behind that trailer. Was right impressed with that load but not the load you pulled. I do know they pulled at good speed for had to meet them and they almost beat me to meeting point.
How does the ride of the two compare and which do you prefer the position you have as to height and such. Will end with admire those who have the ability to pull such a load safely with decent speed. Keeping safe on the road is getting tougher and tougher today. Too many have no idea how to drive around such a rig.
/ Towed heavy yesterday #15
That's the truck I had in mind for a buggy hauler using a car hauler trailer. Throw on 5 or 6 buggies using a crew cab PU for people and tool hauler. Would be wayyyy cheaper than 3 or 4 PUs with goose neck trailers!!! :)
/ Towed heavy yesterday #16
You just need the right trailer and then you can haul it all with the crew cab pickup. See a number of trailer like these around here now days. Seems most of cars are now delivered to the dealers with pickups as apposed to semis.
Double Deck Car Hauler Trailers for sale by Kaufman Trailers
GN6 | 6 Car Hauler Trailers - Infinity Trailers
/ Towed heavy yesterday #17
Yep, see them here too. Buggies weigh 4K each. Hauling six with a 15K lb rig bumps that 40K mark. Rather than do that woth a rig at it's max, I'd feel more comfortable doing it with a rig that's at half it's max. :)
/ Towed heavy yesterday #18
BDog, if you ever need to re-paint your semi, its a pretty close Peterbilt to Optimus Prime. Would look very cool!
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
2017 CATERPILLAR 420F2 BACKHOE (A60429)
2017 CATERPILLAR...
SET OF POLY SADDLE TANKS (A63291)
SET OF POLY SADDLE...
2015 FORD F-150 LARIAT CREW CAB TRUCK (A59823)
2015 FORD F-150...
LOAD OUT AND SHIPPING (A65583)
LOAD OUT AND...
2016 Sky Jack SJ8831RT 31ft 4x4 Rough Terrain Scissor Lift (A61572)
2016 Sky Jack...
