Towed Cultipacker Vs. 3-Pt. Lift Cultipacker - Advantages / Disadvantages?
   / Towed Cultipacker Vs. 3-Pt. Lift Cultipacker - Advantages / Disadvantages? #21
That is one nice packer!!! When do you use it in the discing/planting sequence?? I expect after you disc and again after you broadcast seed (unless you use a drill). My planned build will be similar except with only one set of rollers. Who makes that? I am sure it cost thousands, but is the best looking one I have ever seen. Are you comfortable pulling it down the highway for short trips?
   / Towed Cultipacker Vs. 3-Pt. Lift Cultipacker - Advantages / Disadvantages? #22
It's is a 1960's Brillion and is still made pretty much the same but are very expensive new. Used ones are much cheaper with the smaller ones actually costing more than a bigger size. It is a secondary tillage tool in that after the ground is initially worked it is used to bring things down to a seedbed basis. Then I use a seeding packer to put down the seed. Fields come out looking like a pancake if you do it right. I'll try to get a pic over the next few days.
No problem pulling it down the road since it's only maybe 9 ft wide. I'm only on back roads and have the pulling vehicle is followed by another and both have flashers on.
SIXDOGS:
It looks like the Loch Ness monster, Nessie.
SOME RIG !
You know of what you write.
I visited the Brillion web site for the first time.
Looked at the Brillion "Pulverizer" Model PP.
Model PP web page states: "floating three point hitch linkage" Unfortunately, no detailed photo.
Available in both 3-Point and Towed models.
If Brillion displays at the Sunbelt Ag Expo I will check out floating hitch linkage on 3-Pt. model.
I am going to the Sunbelt Ag Expo to GET SMARTER.....
   / Towed Cultipacker Vs. 3-Pt. Lift Cultipacker - Advantages / Disadvantages? #25
I am going to the Sunbelt Ag. Expo in Moultrie, Georgia October 16-17-18, 2012. I will be there one of the three days.
At top of my shopping list is a CULTIPACKER.
There are a lot of TBN posts on Cultipackers but none comparing efficiency/effectiveness of Towed Cultipackers against 3-Pt. Lift Cultipackers.
It is evident most of the older Cultipackers were towed but a lot of the current offerings are designed for the 3-Point Hitch. Why this change in emphasis?
I am in North Florida. Sandy-Loam, only rocks soft limerock. My tractor is a Kubota B3300SU 33-hp / 1,800 pounds.
Using my 'Bush Hog' Rollover Box Blade there are some issues with the tool going UP when the tractor wheels encounter a LOW spot or a hole; and vice versa. Same issue probable with a 3-Pt. Lift Cultipacker?
(Ken? Ted? Are you out there?)
PLEASE MAKE ME SMARTER. ( Starting low; should not be too difficult.)
The towed cultipacker will follow the ground better and not be jerked around by the tractor 3 point hitch. If you need to move down the highway to different food plots, a 3 point would be the best. Ken Sweet
   / Towed Cultipacker Vs. 3-Pt. Lift Cultipacker - Advantages / Disadvantages? #26
If Brillion will be at the Sunbelt Ag Expo I will check out this implement. Available in 5' model for my tractor....likely $$$$.
I am going to the Sunbelt Ag Expo to LEARN.....
You likely won't see any floating hitch anything. Best bet is to look at the website and learn how to make a connecting link yourself. Buy a standard packer and roll your own. Better bet is to buy a pull-type packer and find a picture of that pull type with a 3-pt hitch welded on to it. It's on the TBN somewhere and you can have the best of both.
It's not hard to spend $5,000 to $10,000 on anything Brillion and even that won't buy much. Their six ft overseeder is $24,000 and cultimulchers start at $13,000 and go to infinity. You'll be learning, allright and lesson one is don't give up the day job.
   / Towed Cultipacker Vs. 3-Pt. Lift Cultipacker - Advantages / Disadvantages? #28
This is not exactly the photo I wanted but shows how to add a 3 pt hitch to an older packer. In this photo the front hitch had been removed but an earlier photo I saw had the front tongue left on. You could shorten the tongue or make it hingable or detachable and you then have a way to transport the packer and yet use it as a pull-type when you get where you are going.
   / Towed Cultipacker Vs. 3-Pt. Lift Cultipacker - Advantages / Disadvantages? #29
That is one of our Brillion's that we have added a three point hitch to. We do leave the factory pull hitch on, if the customer requests. The Combo hitch gives you both ways to pull a cultipacker. Ken Sweet
   / Towed Cultipacker Vs. 3-Pt. Lift Cultipacker - Advantages / Disadvantages? #30
Ken Sweet, can a double axle 8' Brillion be converted to a three point hitch - if so, picture, please - or have an axle with wheels mounted up top to flip over (too heavy?)
PLUS, where do you get Brillion parts these days?
Thanks.
Golf Cart Cargo Box (A56469)
Golf Cart Cargo...
2022 Polaris Ranger 900XP 4x4 Utility Cart (A55853)
2022 Polaris...
2021 Delta Manufacturing 30ft 10-Ton T/A Gooseneck Flatbed Equipment Trailer (A55852)
2021 Delta...
(2) American Range Deep Fryers (A56469)
(2) American Range...
2023 Kubota U55-5R1 Mini Excavator (A55315)
2023 Kubota...
Heavy Duty D-Ring Shackles (A55852)
Heavy Duty D-Ring...
