towbar for ATV
/ towbar for ATV #1
Rgillard
Ireland
Fiat 82-94
Hello,
I am currently building a small trailer that will be used for rolling out sheep wire. It is for the fencing contractor that I work for. I have to weld a towbar onto the back of his quad(ATV) in order to pull this trailer. Where is the best place to weld to. I was going to weld to the frame but it moves with the suspension. Would I be better off taking it from the back axle. The trailer is fairly light and shouldnt put too much strain on the ATV. If anyone has any advice on putting a towbar onto an ATV I would really appreciate it. Dont really want to make a bullocks bag of the back of the ATV.
Cheers
Gilly
/ towbar for ATV #2
ATV tow points are mostly off the rear axle housing. Most manufacturers offer a bolt on bracket for towing. Lots of aftermarket tow hitches available. I wouldn't want to weld to the axle housing, too much risk of weakening the tube or overheating the aluminum differential, or melting a rubber seal.
/ towbar for ATV #3
Hi
here is a pic of my hitch on my ATV.
Charlie.
/ towbar for ATV
Thanks for the photo. Is it just a steel plate welded onto a crossbar on the frame. What sort of attachments do you pull with this. I think i was going to overcomplicate the hitch when maybe a simple plate would be strong enough. Appreciate the help. Thanks.
/ towbar for ATV #5
Hi
we have used it to pull a trac vac model 860 and a yard cart and it works great. Also use it to move or relocate a 16 foot trailer.
charlie
/ towbar for ATV
Am i right in thinking that you welded the steel plate directly to a cross member. is that the only connection there is. is there any need for a 45 degree verticle strut to conteract any turning moment that the towbar will be subject to???
/ towbar for ATV #7
I'm pretty certain that Lazy's atv came with that hitch setup from the factory.
What type (brand and model) atv do you have? This could help us in giving information.
/ towbar for ATV
Im just at work at the minute.i cant remember the manufacturer. The ATV is not mine. Ill try post a picture of the back end of it when I get home in about an hour. That might be more helpful to you guys suggesting idea's. Thanks
/ towbar for ATV #9
Hi
You are correct it came with the hitch. It is a 2 inch receiver tube welded to the frame.
Charlie
/ towbar for ATV #10
Arctic Cat had a heck of a good idea including the 2" receiver tube as part of the package. I like their MRP system too. Other manufacturers need to do something similar.
/ towbar for ATV
here is the back end of the atv.its made by a company called motortek???never heard of them.
/ towbar for ATV
here is the towbar i made for it. After a lot of thought we came up with an idea of being able to catch the towbar behind the crossbar. Then we bolted it to the chain guard which is also pretty rigid. The trailer is fairly light so there wont be much pressure on the quad.left life very easy.here is a pic of the end of the towbar that catches behind the crossbar
/ towbar for ATV
here is the towbar caught on the crossbar
/ towbar for ATV
here is the finished towbar.
/ towbar for ATV
here is it mounted on the atv
/ towbar for ATV
here is the trailer the quad will be pulling. Its not so much a trailer as a tool for rolling out the sheep and barb wire. The wire is simply placed on a bar between the two upright sections. It is then held and the atv then moves forward slowly. it will save two men carrying a crowbar walking 100 metres with the roll then walking back. one man can do it in half the time now.
/ towbar for ATV #18
<<We interrupt this thread to ask a trivial question>>
"Bowhunter, which MRP system did they use?"
<<We now return you to your regularly scheduled dialog>>
/ towbar for ATV
here is the trailer complete and ready for delivery. hope it doesnt fall to bits the first time its used.
/ towbar for ATV #20
Arctic Cat offers a package on their 2004 and newer utility atvs called MRP....Multi-Rack Platform....that allows you to easily add accessories to the racks. Check this link and click on the icon for "The 2004 MRP Models" to find more info.
2019 Ford F-550 Bucket Truck (A64556)
2019 Ford F-550...
2016 FORD TRANSIT T350 EL SRW HI ROOF VAN (A59914)
2016 FORD TRANSIT...
(4) 11R22.5 TIRES ON STEEL WHEELS (A64277)
(4) 11R22.5 TIRES...
2013 DRAGON  130BBL VACUUM TRAILER (A65643)
2013 DRAGON...
48x4 Mini Skid Trencher (A63689)
48x4 Mini Skid...
2020 WESTERN STAR  4900 TRI-AXLE (A65643)
2020 WESTERN STAR...
