Tow vs 3ph disc?
   / Tow vs 3ph disc? #1
valleydweller1
Willamette Valley, Oregon
Kubota B7510
Hi all,
I am in the market for a small disc to tow behind my Kubota B7510. I will be using it to smooth some assorted ruts and holes out on an irregularly shaped acre of soggy ground. Would I be better served with a tow-behind disc or a 3ph mounted disc?
There are a couple of 4-5' tow-behind discs on CL right now for $100.
Greg
   / Tow vs 3ph disc? #2
Tow-behind pull-types get more weight to the ground and weight (and a lot of it) makes the disk work better.
   / Tow vs 3ph disc?
sixdogs said:
Make sure you sell all the puppies before your wife gets attached to them.
That has to be the best quote and screen-name combination I've ever seen.
Greg
   / Tow vs 3ph disc? #4
It's hard to beat a pull type disc for performance. Where they lack is with mobility. Tough to beat a 3-point disc there. A good compromise is a wheel disc. They have most of the advantages and few real disadvantages.
   / Tow vs 3ph disc?
Can a pull-type be backed into position like a trailer or is it a forward-only proposition?
Greg
   / Tow vs 3ph disc? #6
Greg
Sorta like pushing a rope up a hill, but anything's possible. Straighten out the gangs and backing is a little easier, but for the most part, pull-type disc's are meant to go in one direction
   / Tow vs 3ph disc?
Yeah, that's kind of what I thought. I'll go check one out tomorrow.
Greg
   / Tow vs 3ph disc? #8
I have one of each... my pull type is smaller but much more heavy than my 3 point.
"Filter care saves engine wear"
mark
   / Tow vs 3ph disc? #9
So if a guy had a 3pt boom setup or even a PHD frame with the auger removed could you hoist the pull disc up? Or are they too bloody heavy.
   / Tow vs 3ph disc? #10
My 5' pull type would be too heavy to lift with a pole boom and would really flex between the front and rear disc too much to lift.
mark
SCAN TO RECEIVE TEXT UPDATES (A51242)
SCAN TO RECEIVE...
2001 GMC W4 CRANE TRUCK (A51222)
2001 GMC W4 CRANE...
2005 JOHN DEERE 310G BACKHOE (A50458)
2005 JOHN DEERE...
GORMAN RUPP 4 TRANSFER PUMP (A50854)
GORMAN RUPP 4...
Char-Broil Gas Grill (A50860)
Char-Broil Gas...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A49461)
2021 Ver-Mac...
