Tow rope or chain.
   / Tow rope or chain. #1
dj1701
Veteran Member
East Concord, NY
John Deere 4320, Kubota BX2680
Had to pull the Kubota BX out of the mud I got into while mowing. The Mule did a good job, but my cheap rope was cut by the frame of the tractor. The 2nd try I used a strap with open hooks on the ends. I worked but I found open hooks and straps don't mate up so well. I was wondering what all of you use for towing?
Dave
   / Tow rope or chain. #2
Depends honestly...I have a 1/4 inch grade 80 chain for the little stuff. Much easier to carry and deal with over the 5/16 inch grade 70. Also have a kinetic rope for vehicles. You can use a tow strap, and I do have one, but you need good connection points where there is no rubbing to cause fraying or ripping.
   / Tow rope or chain. #3
I've pulled a few vehicles (tractors, trucks, cars) out of the mud over the years. I have used straps but found they would snap and come flying at me. Apparently they must have had a small cut or were frayed. Stopped using straps for that reason and have used chain ever since. Never had a chain break (so far). Mostly I use 5/16" or 3/8" on heavier stuff. sometimes I use axle straps to connect the chain to.
   / Tow rope or chain. #4
We used tow ropes or straps for most towing. (atv's) Exception is we carry a steel choke chain for logs.
   / Tow rope or chain. #5
Use mostly 3/8 inch chains 16 ft long to pull out stuck equipment. Some times have to pull out two vehicles stuck in line with the bigger tractor or excavator. Used a 6 inch wide flexible tow strap when the Unimog was stuck up to the portal axles in mud.
   / Tow rope or chain. #7
I have a few chains floating around, usually keep one on the floor of the Branson. Then I also have one of the kenitic ropes and a couple of the soft shackles that rides in the pickup.
   / Tow rope or chain. #9
2-1/4"-15' grade 70 chain also 3/8" 20' grade,HD strap yet to use.
1/4" chain been my go to chain over the years. (y)
2022 Club Car...
2011 BMW 335i Sedan (A48082)
2011 BMW 335i...
1968 John Deere 4020 with 7ft Mower (A50397)
1968 John Deere...
2013 John Deere 824K (A50397)
2013 John Deere...
2003 Ford F-150 4x4 Crew Cab Pickup Truck (A48081)
2003 Ford F-150...
2015 Kubota RTV-X900 4x4 Utility Cart (A49346)
2015 Kubota...
