tow behind top dressing leveller/spreader
   / tow behind top dressing leveller/spreader #1
Randyr3554
Folks:
I would like to make up or get a spreader/leveller that I can pull behind my rider to spread top dressing and level the lawn.
Was thinking a couple of 4x4s with hardware cloth spread between them might work.
Or maybe chains instead of the hardware cloth?
Or how about making it out of angle iron?
How about brush heads to sweep it into the grass?
What do you think?
Thanks.
   / tow behind top dressing leveller/spreader #2
I have the same need. Did you come up with a solution?
   / tow behind top dressing leveller/spreader #3
I had a similar need, smoothing the yard. Used a leftover A frame from a swing set, really did a good job of spreading and leveling. I used the bucket on my tractor to put out piles of top soil and then pulled the A frame. I used a chain to pull it as it made it easy to adjust the angle of the A frame.
2011 International ProStar T/A Day Cab Truck Tractor (A51692)
2011 International...
2014 International DuraStar 4300 Street Sweeper Truck (A52377)
2014 International...
Heavy Duty Jumper Cables (A51694)
Heavy Duty Jumper...
2011 FONTAINE 48 FOOT STEPDECK (A53843)
2011 FONTAINE 48...
New Holland Boomer 55 Tractor (A52384)
New Holland Boomer...
2011 Case IH Patriot 3250 (A50123)
2011 Case IH...
