Spreader Tow Behind Spreader vs 3ph
/ Tow Behind Spreader vs 3ph #1
MikePA
Super Moderator
PA
Had TC25D, now JD X310
I just spoke with my friendly Agway dealer concerning turning my new 3 acre parcel/lawn into horse pasture. The farmer finally harvested his corn last night with a huge JD harvester. Six lights on the front...looked like a Close Encounters of the Third Kind happening next door. /w3tcompact/icons/smile.gif
Whatever spreader I buy, I want it to spread fertilizer and seed on both the pasture and our lawn. Given our soil conditions, I'm going to be applying lime, probably 3 tons, every year. Of the three types of lime they sell (pelletized, granular, pulverized), he recommended;
1. Pelletized lime - $124.50/ton in 40 lb bags. Can be applied right before seeding. Total Cost: $373.50
2. Spreader - Tow behind spreader like the attached picture. Total Cost: $200.00
3. Seed - Horse mixture grass seed - 25 lb/acre - $52.99/25 lb bag. Total Cost: $158.97
Your thoughts about his recommendations?
/ Tow Behind Spreader vs 3ph #2
Hmmm ... limeing just prior to seed? I'd be worried about the horses grazing a freshly fertilized paddock.
Perhaps my worries are baseless or you have a way to rest the fertilized paddocks before turning out your animals?
We have, or will have, 2 pastures. The new one (2.5 acres) that needs lime and seeding and the existing one (2.0 acres) plus a lawn (.75 acres).
The horses would not be put on the new pasture until the grass is well established and not put on any pasture until 2 weeks (sound OK?) after fertilizing/lime.
The equipment I will buy has to work for both pastures plus the lawn.
/ Tow Behind Spreader vs 3ph #4
<font color=blue>...looked like a Close Encounters of the Third Kind happening next door...</font color=blue>
Gee whiz Mike... you got me all excited... I clicked on your attachment wanting to see that huge giant JD havester... but no....little tiny weenie.../w3tcompact/icons/wink.gif
/ Tow Behind Spreader vs 3ph #5
If you are looking for a tow behind spreader, check out a broadcast spreader, it will be a lot faster. Here is a link for Earthway, they are a little on the pricey side, but I bought a push style last year, and do 2 lawns with it, +/- 2 acres and it is a breeze. I wanted the push behind so i could get into tight areas with it. They have all sizes, and the one i have is built like a tank.
http://www.earthway-outlet.com/index.htm
Sorry /w3tcompact/icons/frown.gif. I should have taken a picture. He was driving towards our house and those 6 headlights were shining through a leyland cyprus hedge, the corn stalks were casting shadows, the ominous rumble of the diesel engine....gotta go carve my mashed potatos. /w3tcompact/icons/wink.gif
/ Tow Behind Spreader vs 3ph #7
Hi Mike. I've got no input on your spreader dilema 'cause I've got the same scenario you do. Seems like that spreader in your picture is awfully small if your planning on doling out 3 tons of lime as well with it. Might work allright just for the seed and fertilizer. As I understand, 2 Horses require a minimum of 4 acres. I plan to rotate grazing between 2-2 acre parcels and have yet to go visit my local feed store to get the mix. I've got time as the house is being built and should be move in time in June-ish-I hope. That gives me lot's of time to prep the earth and get it ready. Does 2 Acres/Horse sound right and what mix are you going to pasture with?
'98 NH 1920 4x4
I've always heard 1 acre/horse, but it depends on the area of the country.
For the pelletized lime, it'd work out to 150 bags, 4 bags/spreader load means I'd have to load the spreader 38 times. Ugh! Some of the 3ph spreaders, e.g., Herd or this one can hold 320 or 750 pounds, but they cost more. Sigh. It's always a money versus time decision. /w3tcompact/icons/wink.gif
When I told Agway the pasture was for horses, they mentioned they have a specific seed mix for horses. Said it doesn't contain any grasses bad for horses.
/ Tow Behind Spreader vs 3ph #9
I would think that Landpride or something like that would be fairly reasonable price. Anyone priced these out??
Kevin
Landpride prices from a local (PA) dealer.
FS500 - $410
FS700 - $430
FS1000 - $450
/ Tow Behind Spreader vs 3ph #11
Not too bad. Considering the tow behind you showed in the photo is $200, I'd say you are definitely getting more than twice the spreader for twice the money. Seems ok. Guess it depends how much $$ a guy wants to spend.
Kevin
/ Tow Behind Spreader vs 3ph #12
Get a broadcast spreader not a drop spreader for field work, you'll cover the area way quicker. Have a look at www.easternfarmmachinery.com they sell herd, vicon, thompson, and gandy drop spreaders and have pricing on their site.
/ Tow Behind Spreader vs 3ph #13
Mike,
Check out TSC/Family/Quality stores in your area for a 3 pt broadcast spreader. Probably get something similar for a little less money.
Terry
/ Tow Behind Spreader vs 3ph #14
Your fertilizer dealer should have spreaders you can rent or use and you can have the lime and fertilize brought over in bulk gravity wagons with augers to unload into a 3pt. spreader. We usually have the trucks dump it right on to the ground and load our spreader with the loader which is faster when you are moving 40 tons of lime. We use the powdered lime because it covers evenly but is quite dusty but could get the pelletized lime also. Your horses won't be affected by the lime or fertilzer as they will not eat enough to hurt them as it taste bad.
<font color=blue>Robert Turk Jr.</font color=blue>
<font color=blue>Whitetail Splendor Deer Farms</font color=blue>
<font color=blue>Silver Creek, NY</font color=blue>
/ Tow Behind Spreader vs 3ph #15
I average at least 3000# of pellitized lime per year, using a 200# capacity drop spreader, with aerators pulled behind my rider when I mow the lawn. Dual duty - mow and lime in one pass and the drop spreader has much better control than a broadcast spreader. I also buy my lime at the end of the season for the next year - bought 40# bags for $.40 at CT Farm and Country this year, bought all they had at 2 different stores.
Once every 10 years I do the hay fields, buying bulk pulverized limestone by the 10 wheeler load, (20+ tons at less than $10/ton) and borrow a pto driven spreader for a weekend.
/ Tow Behind Spreader vs 3ph #16
heck john i did the same thing. expecting to see this big huge green machine. and all i saw was this litle bitty, gt./w3tcompact/icons/frown.gif i think he is a big tease/w3tcompact/icons/smile.gif
2021 Weber CF 2-IIHD Plate Compactor (A61572)
2021 Weber CF...
2014 CATERPILLAR 573C FELLER BUNCHER (A64276)
2014 CATERPILLAR...
Bell 500 Gallon Saddle Tank (A64119)
Bell 500 Gallon...
THREE ROLLING SHOP FANS (A67714)
THREE ROLLING SHOP...
300 GAL WATER TANK (A68842)
300 GAL WATER TANK...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
2018 GENERAC...
