Tow Behind Spreader For JD x530
   / Tow Behind Spreader For JD x530 #1
cyleclayton
Louisiana
John Deere x530, BCS 710 GX8
Need to spread lime, fertilizer and seed about two acres. It's all up and down hill, literally have no flat ground, so I need a stable tow-behind spreader for my garden tractor. Any recommendations?
   / Tow Behind Spreader For JD x530 #2
I had a Rugid 200lbs tow behind spreader from Tractor Supply. It worked well and was quite sturdy. I'm sure it would have lasted me 20years on my old 2 acers, but I upgraded to a 3pt spreader after I got my tractor.
   / Tow Behind Spreader For JD x530 #3
Check out the tow behind ground driven SS1022B
http://www.deere.com/en_US/docs/non_current/DSFE42676_spreaders.pdf
I would not recommend the small plastic tow behinds at Lowes and Home Depot badged by Deere.
If the ground is really rough or hilly (i have hard time picturing much in the way of hills in Louisiana) as you say you might consider one of the electric spreaders that uses the cargo mounting system if your tractor has it. That would certainly reduce the chance of an accidental spillage.
   / Tow Behind Spreader For JD x530 #4
I would not recommend the snall plastic tow behinds at Lowes and Home Depot badged by Deere.
Yeah, the last time i looked at the Deere on in the big box store it looked like a $100 spreader with an extra $150 for the name. Bigest thing I didn't like about it was the cable going to the shutoff. I have found the rod type to work much better than the cable.
   / Tow Behind Spreader For JD x530 #5
Our Agrex pull-type fertilizer spreader will last you a lifetime with proper cleaning and maintenance. They feature a casted, serviceable gearbox, the same heavy duty construction as the 3pt models and outweigh the Frontier model by 37%. We also offer a deflector shield as an option for spreading in close quarters or for salt and sand. All of our fertilizer spreaders ship free to a qualifying business or supporting freight terminal within 1,000 miles of Newton, NC.
Check out the video about the 3pt. model when you click the link above. I hope this helps.
2018 FORD F-150 (A50854)
2018 FORD F-150...
2019 Bobcat T770 Two Speed Compact Track Loader Skid Steer (A50322)
2019 Bobcat T770...
2019 BIG TEX GOOSENECK  TRI AXLE 34FT 2 CAR HAULER (A51222)
2019 BIG TEX...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A51039)
2016 Ford F550 4x4...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2020 Cat 299D3XE Skidloader (RIDE AND DRIVE) (A50774)
2020 Cat 299D3XE...
