chrisjbell
Platinum Member
- Joined
- Jul 17, 2000
- Messages
- 956
- Tractor
- Kubota B7300; JD LX233
I haven't used one of the doohickeys you're talking about, but I have used a number of seeders. I work at a golf course and basically the whole point is growing grass.
All a seeder does is make a small trench with a rotating disk, drops a line of seed in it, and then rolls over it to press it down. What you wind up with are rows of seed, so as has been mentioned if you are planting a grass that is spreading you get pretty good coverage. When we plant rye, for example, it comes up in distinct rows so we generally seed in two (or more) directions (a criss-cross pattern).
The seeders you rent are small versions of the tractor mounted seeders we use (a rental will cover a couple of feet, the big ones are the same thing but PTO driven and a lot wider).
You can get pretty good results by just laying the seed down and raking it in. All grass really needs to grow is to be in contact with the soil and be kept moist. You don't want to bury it too deep or it won't sprout as readily.
Someone suggested tilling, spreading seed, and dragging. We do that with good results. One of the implements we have is a "renovator", which is just disks that spin around and tear up the thatch. After doing that we spread seed and drag and that works nearly as well as using a seeder.
