Tow balls and trailer attachments
   / Tow balls and trailer attachments #1
dince
Versatile 256, 555
Can anyone suggest a source for light weight trailer attachments to suit 50mm tow balls, or preferably smaller tow balls, for lawn tractor trailers, please?
   / Tow balls and trailer attachments #2
You might have to be more specific. Of course in the USA, our trailer hitch balls are generally in inches; i.e., 1 7/8", 2", and 2 5/16". Lawn tractors generally are only equipped with a hole in the hitch to use a pin instead of a ball. In fact, with 1 7/8" being our smallest hitch ball, I don't think one is made with a shank small enough for the hole in the hitch. So I reamed the hole and have a 1 7/8" ball on my Toro.
Dear Bird, Many thanks for your reply and apologies for my belated reply - I have been well and truly off-line! Yes, we have same size balls in australia, and fitting one (1 7/8") to Toro etc will be fine. What I am looking for is the coupling to go on the trailer drawbar, to go onto the ball. I can get cast ones - pretty heavy. I am looking for light weight, pressed steel, ones like are on some wood splitters (Yardman) but don't want to pay their "spare parts" prices! I probably need 10!
   / Tow balls and trailer attachments #5
I don't know about the prices, but they wouldn't be hard to find here, but I have no idea where you'd look in your part of the world.
   / Tow balls and trailer attachments #6
I bought an 1 7/8 at TSC with a pretty small shank. Have to check, it was either 3/4 or maybe 5/8. It would have fit my zero turn hitch hole but the ball was then too close to slip my trailer tongue over. I had to buy an ATV adaptor that used a more standard size shank. Of course I have several of those laying around.
   / Tow balls and trailer attachments #7
It looks like the cheapest one is around $23, due to your standards for couplers which must differ significantly from ours. I'm sure you'd like to find something like this, which is around $10 cheaper, and about twice as much from when I last priced them.
   / Tow balls and trailer attachments #8
View attachment 274349View attachment 274350View attachment 274351View attachment 274352View attachment 274353View attachment 274354View attachment 274355View attachment 274356What with some rain finally, the grass is taking off so I got the mowers out and took some shots I thought might be of interest to this thread. I pull a 66" Swisher with my 60" Woods giving maybe 10 foot of capacity.
Doing a lot of hooking/unhooking, I needed a better way to hook the tow behind than the stock pin. On rough terrain, the mower was hard to "bull" around and pin the tongue. I bought this adaptor from Northern then needed to add a ball. I found a ball at TSC with a 5/8" shank to fit the mower hitch but then the adaptor would not go over the ball. Then I added the "Z" shaped adaptor. After I did that I realized I might have just turned over the hitch/axle mount on the Woods. O'well.
I also have photos of the hitch brace I fabbed up for the Swisher. To me, it felt to "springy" so I fooled around with differnet bracing schemes until I settled on the perforated box tubing which I can adjust to any width. The brackets pin to existing holes for quick removel if needed.
Solo, I have to watch my tail swing with the hitch extention a little but it allows me to jack the tow behind pretty hard without bending the hitch.
   / Tow balls and trailer attachments #10
A local tractor store should have these or can order them.
2020 FREIGHTLINER DEBRIS BUCKET TRUCK (A51406)
2020 FREIGHTLINER...
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A55301)
UNVERFERTH 330 -...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A55218)
2016 Ford F550 4x4...
2018 Volvo MCT 110C (A47477)
2018 Volvo MCT...
1979 MACK R MODEL (A53843)
1979 MACK R MODEL...
1985 Ford Ltl9000 Tender Truck (A55301)
1985 Ford Ltl9000...
