Tougher Tires... I need some
   / Tougher Tires... I need some #21
Look at Gemplers, they have these things called tire liners, they are heavy pieces of rubber that go between the tube and tire that are designed for just such a problem.
Gemplers may well be the proper liner, but what I've seen on highway department mowers is adding metal flashing between the tube liner and the tire. As we all know, highway department mowers run over everything from broken glass to metal parts on the side of highways and in ditches. The flashing method does work!
I once had a similar problem as you with thorn bushes. I'd end up with 12 or 15 thorns in my front tires every morning. That gets old real quick, not to mention the expense and time. So I used the metal flashing method until I got a chance to buy a pair of 14 ply aircraft tires. The tire shop also had 18 ply, in case the 14's didn't stop the flats. But the 14's worked just fine, no matter if I had air in the tire or not :)
   / Tougher Tires... I need some #22
Contact this guy.
Below is some prices he gave me on a 11.2x24 R1
Ben Chatham
Kross Wholesale Tire Co. Inc.
dba Gensco Aircraft Tire
800.847.8473 Toll Free
256.236.5400 Office
256.298.0765 Cell
205.449.6012 Fax
12 PLY Tube Type $176
20 PLY Tubeless $240
Can give shipping cost with a zipcode!
ST225/75R15 Trailer Tires (A55787)
ST225/75R15...
Toro z turn (A56859)
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
UNUSED FUTURE FT-RT57 - 57" HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
2008 TEXAS BRAGG 20 UTILITY TRAILER (A58214)
2008 TEXAS BRAGG...
2017 Gravely Pro-Turn 460 60in Zero Turn Commercial Mower (A55973)
2017 Gravely...
