tough paint
/ tough paint #21
WOW! $214/gallon. Expensive stuff. I think I would have to go with something cheaper when the time comes.
/ tough paint #22
$214 gallon for which product?
Gallon of paint at TSC is about $33 here.
Was looking at TSC primer, and it said not to dilute and to be applied with a brush. That's not what they used to sell.
/ tough paint #23
As far as expensive paint goes, $214/ gallon is still cheap.
/ tough paint #24
I've not had very good luck with tsc paint holding up very well to abuse. Are there tougher paints that are available. I'm not looking for $$$ automotive paints.
are you using hardener?
my tractors and mowers are covered in tsc paint.. and well.. it's still on them after years.. even on the mower sides.
only place paint don't stay is on the parts that engage the ground.. like ripper teeth and plow s and chissle teeth.
soundguy
/ tough paint #25
since bps paints finally got the new valspar name this year?.. some shades ahve changed.. and so did the primer.. etc.
I still sprayed the new primer using the old can directions and had no issues thinning with MS or naptha.
soundguy
/ tough paint #26
soundguy
I am referring to high end automotive finishes.
/ tough paint
soundguy
No hardener. I worry about the iso's.
/ tough paint #29
Industrial enamel is fine without the hardener. Before you get too caught up in the hysteria worrying about iso's, you should realize that the paint is still full of harmful, toxic, cancer causing chemicals, WITHOUT adding the hardener. The EXACT same protective equipment is STILL required when spraying it, either way. :thumbsup:
/ tough paint #30
there goes some of the paints toughness. valspar tractor paints without hardner are quite a bit different compaired to finish's where hardner was used.
soundguy
/ tough paint #31
Whenever I can, I have my stuff powder coated rather than paint.
100 times more durable, and the bond is forever.
If you build lots of stuff, develop a relationship with your favorite powdercoating establishment. That way you can drop off small parts that can go in with someone elses larger order, thus avoiding the minimum charge.
:thumbsup:
That's what I do, and I'm pleased with the results.
/ tough paint #33
How do they PC and 6' bush hog or a set of pattet forks?
Same as anything else :cool:
Seriously it depends on your shop. The shop I use can do entire cars, trailers, etc...needless to say they have a massive facility.
/ tough paint #34
If you want paint that cures as hard as steel then get yourself some Hammerite paint. I've used this stuff for 30years and it always gives me excellent results and really is as hard as nails.
Recently Killz has bought them out. But they still produce the same great product under the Hammerite name.
Hammerite has two versions of paint, rust resistant and rust encapsulating.
I use the rust encapsulating on old machinery like my cultivators. It is every bit as good as POR 15 and far, far less expensive.
They have smooth finish and hammered finish and I use both in different applications.
They have a good selelction of colours but don't have any manufacturer's match colours otherwish my bushog and my sickle mower would certainly be painted with it.
Give it a try I know you'll like it.
/ tough paint #36
There is a paint i use when i want toughness It's called INDURA just google the website. This paint is actually plastic and has been used by the Canadian Gov to paint an F_18 fighter jet. About half the price of auto paint. The Hot Rod community has turned out wonderful jobs.
You really have to check out thier site
/ tough paint #37
Sorry I mis spelled the name it is ENDURA NOT Indura
/ tough paint #38
Unless you are painting a combine, you'll find that a quart is good for something up to the size of, say, a utility trailer. The paint has a lot of solids so you don't need more than two coats.
/ tough paint #39
and good primer makes paint go alot farther.
soundguy
/ tough paint
I was thinking about trying to spray some paint with hardeners (iso). I see there are a couple of ebay sellers selling disposal supplied air hoods. I was thinking about getting some of these and wearing my mask (with new cartridges) and one of these hoods connected to my compressor as well. Good idea or bad?
2014 Chevrolet Tahoe SUV (A64194)
2014 Chevrolet...
2022 EZ-GO ELITE...
CATERPILLAR PC306 PLANER (A65053)
CATERPILLAR PC306...
2013 Ford Flex SUV (A64557)
2013 Ford Flex SUV...
2010 Chevrolet Tahoe SUV (A64194)
2010 Chevrolet...
2022 EZ-GO ELITE...
