Touch up paint for new jd and equipment
   / Touch up paint for new jd and equipment #1
JD3520
TEXAS
JD 3520
I have added some tool boxes made of old army ammo cans to my jd3520 and some equipment. Used rust-oleum farm equipment paint to paint them. I wasn't expecting much but boy was I surprised. And less than $5.00 a can.
The "matches john deere green" color matched almost perfectly. You can't tell the difference until you catch the light just right and if someone is looking at my tractor that close they won't see the board hitting them in the back of the head!!!
Seriously though, I do not know who durable this paint is. Does anyone have any experience with this paint or know of another paint that will match that well and be durable?
   / Touch up paint for new jd and equipment #2
</font><font color="blue" class="small">( ....or know of another paint that will match that well and be durable? )</font>
yup John Deere paint.
/forums/images/graemlins/grin.gif
   / Touch up paint for new jd and equipment #3
If you don't mind, where did you mount the cans?
   / Touch up paint for new jd and equipment #4
send some pics of your new tool boxs I am curious. I have looked a couple of times and haven't figured out were I would put one. The factory tool box once you put a pair of gloves, and pair of pliers it is full. So send some pics
   / Touch up paint for new jd and equipment #5
Here's my non-welders attempt at an onboard tool box using an ammo can. Not ideal, but functional. I would like to carry my chain, but the way this is set up, it can't handle that much weight over my rough pasture. The holes in the ROPS are all ready there on my 3320.
ToolBox 1 ToolBox 2
Sorry it took so long to respond. I had camera problems. Please excuse me. This is the first posting with pics.
here's another
i am planning to attach something on the left side like a greese gun holder. my quick hitch is used for all my attachments (except the phd) both 3 pt and others.
last pic.
   / Touch up paint for new jd and equipment #9
JD3520
Nice tool box and location.
Noted your intended useage, and just wanted to pass on a suggestion of changing out some of the clips and hitch pins at three locations to bolts and lock nuts. I learned early on that the hitch pins can catch on sticks and things, get pulled out, and then the 3pt arms are loose to possibly cause damage (have heard as serious as broken castings, and less serious, bending of components). I posted your pic with three of the locations marked that I have switched over to bolts (I seldom if ever remove those clips at those locations anyway, except the times I remove the iMatch). ¼" bolts with locknuts is what I use and then don't worry about losing them.
   / Touch up paint for new jd and equipment #10
There are a couple other points I changed out too, that is at the rocker arm and the lower 3pt arms. Total of 5 on each side. I guess the hitch pins and clips look 'cool' over bolts, but the bolts will stay put.
I won't feel bad if you (or any others) don't see fit to do this. /forums/images/graemlins/wink.gif
2009 Pontiac G6 Sedan (A51694)
2009 Pontiac G6...
Vermeer D16X20A Directional Drill with Mixing System and Trailer (A51573)
Vermeer D16X20A...
378507 (A51573)
378507 (A51573)
New/Unused 7ft Stainless Steel Workbench (A51573)
New/Unused 7ft...
2022 Wacker Neuson SM100 Mini Skid Steer (A53472)
2022 Wacker Neuson...
2011 GMC SIERRA 2500HD (INOPERABLE) (A52472)
2011 GMC SIERRA...
