Totally OT: Power Plant tour
   / Totally OT: Power Plant tour #1
Cord
Richfield, Wi
Resident Architect
Had an opportunity today to walk through a coal fired power plant. Thought maybe you'd appreciate seeing the inside of one. Security was surprisingly simple. Once we got through the front gate, we pretty much had unescorted access. Probably would be different if this was a nuclear plant.
  • Pile Cap - Inside.pdf
  • Turbine Generator.pdf
  • Start of the Electric Grid.pdf
  • Transformer.pdf
  • Coal Pulverizers.pdf
  • Boiler - Level 1.pdf
  • Pile Cap - Outside.pdf
   / Totally OT: Power Plant tour #2
Pretty cool, thanks for posting. Is pulverization the same as coal gasification?
I'm only a lowly architect, so I'm not certain, but I suspect you are onto something. The bottom of each pulverizer had the paint burned off and they were very hot. Could feel the heat radiating off them from 10' away.
   / Totally OT: Power Plant tour #4
   / Totally OT: Power Plant tour #5
For 14 years I been in power plants working to fix them.
Boiler makers local 107
   / Totally OT: Power Plant tour #6
those pulverizers look like journal type mills and yes the powder that is blown into the boiler is highly flammable, where is this plant it sure looks clean compared to some I have seen.
   / Totally OT: Power Plant tour #7
Pulverization just makes very fine coal dust, not gas, that can be fed in to fire a boiler on a more consistent basis. Think of it like an auto feeder on a wood pellet stove VS stoking a stove with large chunks of wood. Gasification makes actual gas that they can pipe to other locations like natural gas. There used to be a gasification operation in DTSB well before we were born. I think somewhere around either the Century Center or the old NIPSCO gas tower between Miami and Fellows.
Wisconsin, on the shores of Michigan. Yes, it was a lot cleaner than I was anticipating. After the sugar explosions, OSHA has been really cracking down on dust control.
   / Totally OT: Power Plant tour #9
uploadfromtaptalk1469017347659.jpguploadfromtaptalk1469017383398.jpguploadfromtaptalk1469017398642.jpg
Here a few pics. I took through the years in the trade. The pic. With the crane in a SER going up on the shore of the lake.Another one is looking up in a small fire box. And last is the supports that hold up the water walls for the boiler.
2011 IC Corporation PB105 School Bus (A52377)
2011 IC...
2016 Kenworth T880 Tri-Axle Brenner 4000 Gallon Water Tanker Truck (A51692)
2016 Kenworth T880...
2005 Superior Trailers VT130 T/A Vacuum Trailer (A51692)
2005 Superior...
Year: 2000 Make: Ford Model: F-150 Vehicle Type: Pickup Truck Mileage: 183122.9 Plate: Body Type: 4 (A53422)
Year: 2000 Make...
2018 Mercury Verado 250HP Outboard Boat Motor (A51694)
2018 Mercury...
AGT Air Compressor (A50123)
AGT Air Compressor...
