TOTAL NEWBIE HERE - Brush Hog Question
   / TOTAL NEWBIE HERE - Brush Hog Question #1
justmike612
Ottawa
Generic lawntractor
I just inherited a grout pump machine. GS1000 Grout Pump | Probe Support Services
It has a Honda 5.5hp GX160 engine with a Parker D07AA2A-R hydraulic pump which has a displacement of 0.168 CU.IN./REV
Parker - D07AA2A-R
I also have a 54in PTO cutting deck which I want to convert to a pull-behind ATV brush hog.
The hydraulic pump on the grout system has a 6Gal hydraulic reservoir and the Parker pump drives a piston type pump for the grout which spits out only 2.3gal/m at 1000psi
My question is:
What do I need to get in order to drive the cutting deck with that rig?
Or can I at all?
   / TOTAL NEWBIE HERE - Brush Hog Question #2
I know very little about hydraulic design. But I think a 5.5 hp engine is going to have a hard time turning a 54 inch deck no matter how you hook it up. I think I am right in saying generally a hydraulic drive system is not very efficient, so it's going to require even more horsepower with some sort of hydraulic drive.
   / TOTAL NEWBIE HERE - Brush Hog Question #3
Not sure what you want to cut - brush or grass, but for a 54 [in] deck, I'd want a minimum of 20 [hp] delivered to the deck (after losses).
This is based on running a 60" deck on a 26.5 [hp] PTO machine.
   / TOTAL NEWBIE HERE - Brush Hog Question #4
Yep. 5.5 hp with hydraulic losses is going to make a pathetic 54" mower
   / TOTAL NEWBIE HERE - Brush Hog Question #5
I have not idea what that grout pump is worth, all I know is when I have looked at grout pumps in the past they were pricy items,
but I would guess if it is in good shape one could sell that, and buy a new ATV mower out right,
2024 TIMPTE HOPPER 43FT HOPPER TRAILER (A53426)
2024 TIMPTE HOPPER...
377789 (A51573)
377789 (A51573)
2009 IC Corporation PB105 Passenger Bus (A51692)
2009 IC...
(3) UNUSED MR HEATER PORTABLE PROPANE AIR HEATER (A51247)
(3) UNUSED MR...
40' High Cube Multi-Door Container (A50123)
40' High Cube...
3 BATTERY CHARGERS (A53843)
3 BATTERY CHARGERS...
