Backhoe Total length of BX25 with Backhoe
   / Total length of BX25 with Backhoe #1
CAS300D
New Jersey
TBD
Doing some planning in the garage, what is the total length of a BX25 with the front bucket and the Backhoe attached
Thanks
   / Total length of BX25 with Backhoe #2
I come up with just under 15'6" with the front bucket flat on the ground and the backhoe pinned for storage.
   / Total length of BX25 with Backhoe #3
But if you swivel it to one side you can save a few inches. I'd measure mine, but it's off right now in favor of my chipper. I can say that it fits in a 16' shed with a foot or so to spare.
   / Total length of BX25 with Backhoe #4
Here's a pic of mine, sitting on a 16-ft trailer. Don't forget door height: you'll need a minimum 8-ft door to get through without folding ROPS down.
   / Total length of BX25 with Backhoe #5
just remembered that i have a ati corp. quick attach on the front bucket that adds 4"-6" to the length so it maybe 15' with out it.
   / Total length of BX25 with Backhoe #6
When I measured mine, it was right around 15'.
(this is not "scientific" by any means) ;)
   / Total length of BX25 with Backhoe #7
When I built my new garage addition for my BX24, I made it much longer then 16 ft. Reason is that sometimes I take FEL off in garage and it takes couple feet of space. Same with BH. when the FEL and BH is attached - the leakdown of boom makes the joint stick out roughly 3 ft or so and that would've hurt my newly installed doors if I didnt have enough length in garage. So If I were you IMHO go a minimum of 25 long so you have room in front and back to walk around with attachments off.
   / Total length of BX25 with Backhoe #8
There is no such thing as a big enough garage.... I had a 18x38' barn/garage built for the toys and it's still not enough. The Bass boat is the biggest space offender. I recomend having big doors on both ends. It has simplified my life a lot.
   / Total length of BX25 with Backhoe #9
When I built my first garage, (30' x 36') told my dad it wasn't big enough. His reply: When you finally get around to build one big enough you won't need it anymore.
Chris,
Can I get a quick call with you, I am trying to make a decision and you will be most helpful in that process,
Thanks,
Chuck
908-202-3376
Thanks Chris
(4) Split Suitcase Weights (A50515)
(4) Split Suitcase...
JOHN DEERE 3025E TRACTOR (A51243)
JOHN DEERE 3025E...
Spool 19mm Wire Rope (A47384)
Spool 19mm Wire...
2020 CATERPILLAR D3 LGP CRAWLER DOZER (A51242)
2020 CATERPILLAR...
UNUSED FUTURE FT-E48 ELECTRIC BICYCLE (A51244)
UNUSED FUTURE...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
