Backhoe Total length of BX25 with Backhoe
   / Total length of BX25 with Backhoe #1
CAS300D
New Jersey
TBD
Doing some planning in the garage, what is the total length of a BX25 with the front bucket and the Backhoe attached
   / Total length of BX25 with Backhoe #2
I come up with just under 15'6" with the front bucket flat on the ground and the backhoe pinned for storage.
   / Total length of BX25 with Backhoe #3
But if you swivel it to one side you can save a few inches. I'd measure mine, but it's off right now in favor of my chipper. I can say that it fits in a 16' shed with a foot or so to spare.
   / Total length of BX25 with Backhoe #4
Here's a pic of mine, sitting on a 16-ft trailer. Don't forget door height: you'll need a minimum 8-ft door to get through without folding ROPS down.
   / Total length of BX25 with Backhoe #5
just remembered that i have a ati corp. quick attach on the front bucket that adds 4"-6" to the length so it maybe 15' with out it.
   / Total length of BX25 with Backhoe #6
When I measured mine, it was right around 15'.
(this is not "scientific" by any means) ;)
   / Total length of BX25 with Backhoe #7
When I built my new garage addition for my BX24, I made it much longer then 16 ft. Reason is that sometimes I take FEL off in garage and it takes couple feet of space. Same with BH. when the FEL and BH is attached - the leakdown of boom makes the joint stick out roughly 3 ft or so and that would've hurt my newly installed doors if I didnt have enough length in garage. So If I were you IMHO go a minimum of 25 long so you have room in front and back to walk around with attachments off.
   / Total length of BX25 with Backhoe #8
There is no such thing as a big enough garage.... I had a 18x38' barn/garage built for the toys and it's still not enough. The Bass boat is the biggest space offender. I recomend having big doors on both ends. It has simplified my life a lot.
   / Total length of BX25 with Backhoe #9
When I built my first garage, (30' x 36') told my dad it wasn't big enough. His reply: When you finally get around to build one big enough you won't need it anymore.
Chris,
Can I get a quick call with you, I am trying to make a decision and you will be most helpful in that process,
Thanks,
Chuck
908-202-3376
Thanks Chris
2017 Ford Fusion Sedan (A50324)
2017 Ford Fusion...
2014 FREIGHTLINER S/A SERVICE TRUCK (A51243)
2014 FREIGHTLINER...
2023 CATERPILLAR 299D3 XE SKID STEER (A51242)
2023 CATERPILLAR...
UNUSED FUTURE MINI EXCAVATOR HYD BREAKER (A51244)
UNUSED FUTURE MINI...
2016 Ford Fusion Passenger Car, VIN # 3FA6P0G79GR191653 (A50324)
2016 Ford Fusion...
UNUSED TOPCAT HDRC HYD QUICK ATTACH BRUSH CUTTER (A51244)
UNUSED TOPCAT HDRC...
