TOS for Kubota BX2230
   / TOS for Kubota BX2230 #1
Lrobby99
Greendale
Kubota BX2230
Hi: Would anyone happen to have the P/N for the Tip Over Switch for a BX2230?
Thanks in advance
   / TOS for Kubota BX2230 #2
Hello Lrobby99. I have a 2004 2230 and would gladly offer you a reply but am unfamiliar with your term "tip over switch". Could you maybe get a picture? Or, you could go to kubotabooks.com and view your part online by looking up model and going through the manuals that they have. I have done this many times to be sure what to ask for at the dealer.
Hope you find your part, Best of luck. Robin C.
The TOS is located under the dash close to the left side. Looks like this.
thanks much
   / TOS for Kubota BX2230 #4
I will look under the dash tonight to check it out, as I have not noticed that item before. How do you know that it is a tip over switch if it is not labeled as such??
The label indicated TOP and indicates mounting direction. Interesting got my curiosity up now. Did you have any luck in looking at kubotabooks.com?? That's where I am turning to after I write this note.
   / TOS for Kubota BX2230 #5
Well looked at the unit on the firewall next to the flasher unit. it is a "timer, key stop" P/N T0070-31410
My work shop manual does not show a tip over switch it does show a timer relay which I think this unit is.
In going to Kubotabooks.com I have found that the search tool/box for looking up the 2230 you put in 2230D and you will find everything that there is to diagram on your Kubota 2230, including all the part numbers
Hope this helps...........Robin C.
Thank you very much.
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
New/Unused 10ft 40 Drawer Workbench (A51573)
New/Unused 10ft 40...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2017 FREIGHTLINER...
2007 FORD F-450 SUPER DUTY (A52472)
2007 FORD F-450...
2001 Volvo VNL Truck, VIN # 4V4N19JF51N250353 (A51572)
2001 Volvo VNL...
