Torquing Components with O-Rings
/ Torquing Components with O-Rings #1
browndd1
How critical is it that you use torque specs when installing something like a lift cylinder to a lift housing that contains several o-rings? If you torque it too tight can it effect the o-rings or does it really matter?
/ Torquing Components with O-Rings #3
Are you talking about torquing the oring fitting or torquing the assembly together?
Bill
/ Torquing Components with O-Rings #4
ditto what hooked said.
are we talking orf/orb fittings.. or a .. say.. adapter plate like a power beyond plate that may sandwich to a housing with oring connections, yet has bolts holding it to the casting?
big difference.
soundguy
The lift cylinder that contains the piston bolts to the lift housing and there are a few o-rings in between these two. I think there are three bolts
/ Torquing Components with O-Rings #6
You need to at least get in the ballpark but probably the most important thing is to torque them all evenly. When fasteners are all different torque, things tend to warp.
Steel Concrete Wall Panels (A61166)
Steel Concrete...
GMC 2500HD 4wd Service Truck (A63118)
GMC 2500HD 4wd...
2017 International ProStar Truck, VIN # 3HSDJAPR4HN677698 (A61165)
2017 International...
UNUSED JCT QUICK ATTACH 60" PALLET FORKS (A62131)
UNUSED JCT QUICK...
Rhino 1540 Blade (A63116)
Rhino 1540 Blade...
2016 Ford E-350 Passenger Bus (A61568)
2016 Ford E-350...
