Torque wrench
/ Torque wrench #1
Haz
Northeast PA
Kubota L3430cab w/ FEL
Just got my L3430 Kubota last weekend. I have most of the tools I need already for maintenance but I don't have a torque wrench. Is it something that I need? Also what are some good brands to buy? Thanks
Haz
/ Torque wrench #2
No need to spend a lot of money. A Craftsman from Sears will do you fine. I suggest a 3/4" drive micrometer setting ("click") type of wrench. ½" drives would be OK, but tightening the blades on a mower deck might require a 3/4".
Should go to at least 150 ft-lbs.
/ Torque wrench #3
Agree on the micrometer. I have the old fashioned bar type torgue wrench and it is a bear. Makes me think that I will take it back as the indicator rod is bent and I have to add or subract a bit to get the right value....I'll trade up to the micrometer....I like the idea of being able to concentrate on work and just listen for the click!
/ Torque wrench #4
I just got the 1/2 inch drive bar type wrench. I use my wife to spot for me as I crush in to it. A click type would be better I guess, but I wanted the tool length for leverage. It ain't easy to push 108 ft lbs! At least not when you're a sissy hand engineer like me. /forums/images/graemlins/wink.gif
/ Torque wrench #5
I have one of each. You get what you pay for. I had a $19 click type from Harb Freight that lasted 5 days,rebuilding a 72 Chevelle. I now have Craftsman.
/ Torque wrench #6
Haz,
You have gotten some good advice. The micrometer clicker types are certainly they way to go. I occasionally use a 3/4" drive job at work for up to 450 ft lbs. Also use a needle sweep with a multiplier to get about 1200 ft lbs. That's a bear.
One point about the clicker style that hasn't been mentioned is proper care. The adjustment mechanism uses a spring. If you store it loaded up, eventually the spring will weaken and be out of calibration. It will take a long time (many months, maybe even a few years) to do the damage, but you'll likely have the wrench for a really long time. Simple maintenance to back off the load after each use. We try to do that at work, but then our wrenches go out for calibration annually.
Nick
/ Torque wrench #7
I used to do those cals in the USAF -- the 2 primary reasons a wrench would be out of cal -- getting dropped - and being left at a setting other than the lowest setting on the wrench... where it should always be stored at.
/ Torque wrench #8
Mike makes a very important point. Always unload the adjustment knob on the clickers after use if you want them to be accurate and treat them like a fairly delicate measuring tool. Always use slow even pulls then using them, don't do fast little jerking pulls, they won't be accurate if you do.
/ Torque wrench #9
Avoid taking the wrench apart. Also, do not lubricate it. Both will affect the final readings. Purchase an injected molded storage case to protect the torque wrench. A calibration service told me that a newer torque wrench is more likely to be out of calibration due to the breaking in of new parts. After initial break-in, a quality torque wrench will hold it's calibration for approximately 10,000 cycles. I own a 3/8" Sears DigiTorque and a 1/2" Proto. These guys have calibrated both wrenches and I was pleased with their work and price. Team Torque
/ Torque wrench #10
<font color="blue"> Purchase an injected molded storage case to protect the torque wrench. </font>
I picked up a pretty nice clicker version from a Napa store a few years back that came with the molded case. I paid $34.95, according to the price tag that I never took off /forums/images/graemlins/smile.gif. Seems to work well - I've "tested" it against a neighbor's "guage" wrench and they were pretty darn close to each other. But I am careful to unwind it before storage.
Yeah, before y'all start - I probably could have gotten a Craftsman for less. But I was already at the store /forums/images/graemlins/blush.gif /forums/images/graemlins/laugh.gif.
/ Torque wrench #11
If you are referring to the type with the beam and a indicator bar mounted above it, as long as the beam has not been damaged, you can bend the pointer into position so that it points to zero when the wrench is not under load. The indicator rod can get bent as it rattles around in the tool box. Just bend it back!
/ Torque wrench #12
Hi Chris.
Just curious - how did you peform that test?
/ Torque wrench #13
I don't see that you are any better off with a Craftsman than with the HF junk. The Craftman free replacement guarantee is useless for something like a torque wrench that can fail without you knowing it. I bought two of their top of the line torque wrenches and both were not worth the cost of the fancy plastic case they came in. They could not be calibrated so are worthless for their intended purpose. They could serve as spare ratchets though. I would trust a beam torque wrench before I would a Craftsman.
/ Torque wrench
R_Squared
I was looking on ebay and found some used torque wrenches that looked like they are in good shape. The had some Proto and Snap-On wrenches that were a pretty good price. I noticed there were some of the clicker type and some with what appears to be a round guage (sort of like a pressure guage). Which type is more accurate? They seemed to be around the same price. Thanks for the tip on the calibrating service.
Haz
/ Torque wrench #15
There's a whole lot more to using a torque wrench than hearing the click of the micrometer type. If you are doing a wheel bearing, you spin the wheel and look at the indicator of a beam type torque wrench - something you can NOT do with the micro type - the sometimes not so subtle difference between digital (micro) and analog (beam). How about the threads - are they clean? Lubed? Did you use Neverseize? Is there a gasket in the equation?
Start out with the beam type, make sure the handle is centered when you use it, then, when you know what you are doing, get a micro.
/ Torque wrench #16
"with what appears to be a round guage (sort of like a pressure guage). "
That's a <font color="blue">dial indicating </font> type torque wrench.
I've used all types....good point about rolling the micrometer setting (click) back to zero between uses...but the best type for home use is the micrometer setting, but as mentioned, not the best for all applications (wheel bearings). Easiest to use, though.
/ Torque wrench #17
<font color="blue">back to zero between uses </font>
A little clarification here ... You DO NOT try to set a wrench back to "0" -- instead you keep it stored at "the lowest setting" which is not "0" Turning it past the lowest setting is almost as bad as keeping it loaded when you're done with it.
/ Torque wrench #18
Haz,
The dial types are usually more expensive. Call a calibration center to get an explanation. They service the instruments and see the various problems. They might even give you a specific manufacturer/model to fit you application.
2012 International 4300 Reefer Truck (A61306)
2012 International...
Hobart Champion 16 AC/DC Engine-driven Welder and generator (A61307)
Hobart Champion 16...
2016 Ford Transit 350 Cargo Van (A59230)
2016 Ford Transit...
2024 Kubota RTVXG850GLAS24-A Sidekick Utility Vehicle - 19 hours
2024 Kubota...
JOHN DEERE 750 (A58214)
JOHN DEERE 750...
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
