Torque wrench
   / Torque wrench #1
Haz
Northeast PA
Kubota L3430cab w/ FEL
Just got my L3430 Kubota last weekend. I have most of the tools I need already for maintenance but I don't have a torque wrench. Is it something that I need? Also what are some good brands to buy? Thanks
Haz
   / Torque wrench #2
No need to spend a lot of money. A Craftsman from Sears will do you fine. I suggest a 3/4" drive micrometer setting ("click") type of wrench. ½" drives would be OK, but tightening the blades on a mower deck might require a 3/4".
Should go to at least 150 ft-lbs.
   / Torque wrench #3
Agree on the micrometer. I have the old fashioned bar type torgue wrench and it is a bear. Makes me think that I will take it back as the indicator rod is bent and I have to add or subract a bit to get the right value....I'll trade up to the micrometer....I like the idea of being able to concentrate on work and just listen for the click!
   / Torque wrench #4
I just got the 1/2 inch drive bar type wrench. I use my wife to spot for me as I crush in to it. A click type would be better I guess, but I wanted the tool length for leverage. It ain't easy to push 108 ft lbs! At least not when you're a sissy hand engineer like me. /forums/images/graemlins/wink.gif
   / Torque wrench #5
I have one of each. You get what you pay for. I had a $19 click type from Harb Freight that lasted 5 days,rebuilding a 72 Chevelle. I now have Craftsman.
   / Torque wrench #6
Haz,
You have gotten some good advice. The micrometer clicker types are certainly they way to go. I occasionally use a 3/4" drive job at work for up to 450 ft lbs. Also use a needle sweep with a multiplier to get about 1200 ft lbs. That's a bear.
One point about the clicker style that hasn't been mentioned is proper care. The adjustment mechanism uses a spring. If you store it loaded up, eventually the spring will weaken and be out of calibration. It will take a long time (many months, maybe even a few years) to do the damage, but you'll likely have the wrench for a really long time. Simple maintenance to back off the load after each use. We try to do that at work, but then our wrenches go out for calibration annually.
Nick
   / Torque wrench #7
I used to do those cals in the USAF -- the 2 primary reasons a wrench would be out of cal -- getting dropped - and being left at a setting other than the lowest setting on the wrench... where it should always be stored at.
   / Torque wrench #8
Mike makes a very important point. Always unload the adjustment knob on the clickers after use if you want them to be accurate and treat them like a fairly delicate measuring tool. Always use slow even pulls then using them, don't do fast little jerking pulls, they won't be accurate if you do.
   / Torque wrench #9
Avoid taking the wrench apart. Also, do not lubricate it. Both will affect the final readings. Purchase an injected molded storage case to protect the torque wrench. A calibration service told me that a newer torque wrench is more likely to be out of calibration due to the breaking in of new parts. After initial break-in, a quality torque wrench will hold it's calibration for approximately 10,000 cycles. I own a 3/8" Sears DigiTorque and a 1/2" Proto. These guys have calibrated both wrenches and I was pleased with their work and price. Team Torque
   / Torque wrench #10
<font color="blue"> Purchase an injected molded storage case to protect the torque wrench. </font>
I picked up a pretty nice clicker version from a Napa store a few years back that came with the molded case. I paid $34.95, according to the price tag that I never took off /forums/images/graemlins/smile.gif. Seems to work well - I've "tested" it against a neighbor's "guage" wrench and they were pretty darn close to each other. But I am careful to unwind it before storage.
Yeah, before y'all start - I probably could have gotten a Craftsman for less. But I was already at the store /forums/images/graemlins/blush.gif /forums/images/graemlins/laugh.gif.
HLA 2500 8' Snow Pusher Bucket (A52349)
HLA 2500 8' Snow...
2013 Ford F-250 XL (A50120)
2013 Ford F-250 XL...
Xtreme XR1045 (A50120)
2020 Bobcat T76 R-Series (A47384)
2020 Bobcat T76...
2014 Chevrolet Tahoe SUV (A50324)
2014 Chevrolet...
Farm Star 4' Off Set Disk (A50515)
Farm Star 4' Off...
