Torque specs for YM1700
   / Torque specs for YM1700 #1
kayssupply
Platinum Member
S Illinois
Iseki TA 207
I am putting a YM1700 back together. Does anyone have the Specs for bolt torque on it?
   / Torque specs for YM1700 #2
This was what was given to me when I was rebuilding mine.
Head bolts 95lbs
rod bolts 38lbs
valves .006 exhaust .008 intake at TDC
Eddie
Does anyone else have any numbers. I had 130# on the head bolts. I want to be sure.
   / Torque specs for YM1700 #4
From the I & T Shop Manual for YM195, engine 2T84A. (US version YM1700). I recommend the I & T Shop Manual for anyone if it covers your model.
Head bolt with oiled threads, 127-134 ft lbs.
(my own advice is let it sit overnight then re-torque).
Rocker support nuts 48 ft lbs.
Intake and exhaust both .006" at TDC, cold.
(There is an Injection mark on the front pulley an inch or so ahead of the TDC mark. #1 cylinder is at rear (flywheel end of the engine). Firing order #1 then 180 crank degrees later, #2.)
Decompression lever: in decompresson position, at TDC on that cylinder's compression stroke, just snug then one turn. (about .031 open)
Thanks, I really do appreciate the help. Good, complete info to work with. I have that manual, but must have missed the specs.
   / Torque specs for YM1700 #6
My YM 1700 has the 2TR17-A engine in it. Are you sure you have the right engine number?
   / Torque specs for YM1700 #7
Reed, after reading Dick's question I think the specs I quoted are relevant for YM1700 but I don't have the information to be certain.
Dick, thanks for the heads-up. That sent me into researching the manuals I have here.
I verified that the I & T book says YM195/engine 2T84A.
The Parts Catalog issued by Yanmar-USA for YM195/YM240 also says YM195/engine 2T84A. So that is what they call the smaller USA engine. This all seems strange, because the next larger size tractor YM240 (sold by Yanmar USA) and YM2000 (Japan) both share one engine, model 2TR20A-X.
Back in the I & T book, they list identical procedures, torque, etc for YM195 and YM240 so the difference between those engines seems to be only the displacement, and the YM240's water pump.
So to me it is not certain that Reed's YM 1700/2TR17-A engine is identical to the US YM195/2T84A engine but I think it is.
I looked in another source here, a YM195/YM240 USA Flat Rate Manual. It shows identical labor hours for YM195 or YM240 on all listed tasks, so a 2T84A engine must be pretty similar to a 2TR20A-X.
   / Torque specs for YM1700 #8
This is where I was given the specs I used to put my 1700 back together.
   / Torque specs for YM1700 #9
Head Bolts 130 + or - 3.6 lbs
Rocker Arm Support 58 - 72 lbs
Rod Bolts 33 - 36 lbs
Valves .006 in
Danny
Thanks, everyone. It fired off first spin. Pops like a pop corn popper. I spun it until the oil light went off a couple times and then let her go and away it went. If he will break it in slow and keep the radiator clean it should go the 5000 more hours it should have went the first time.
1995 Case IH 2144 Combine (A50514)
1995 Case IH 2144...
2000 MACK RD688 TRI AXLE DUMP  TRUCK (A51222)
2000 MACK RD688...
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A52128)
John Deere 5090E...
2008 INTERNATIONAL 4300 M7 SBA 4X2 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
2803 (A50460)
2803 (A50460)
2008 Ford F-350 4x4 Pickup Truck (A50323)
2008 Ford F-350...
