Torque specs for i3040
/ Torque specs for i3040 #1
Alaska247
Alaska
3040i
Hello!
I'm hoping someone can help me with LS recommended torque specs. I had to replace the part that is used to connect the 3PH stabilizer to rear axle. These bolts are also used to secure the ROPS to the rear axle. They are 14mm grade 10.9 bolts, so I'd assume normal torque would be something like 110 lbs-ft. But I'd like to use LS recommendation if they exist.
Thanks in advance!
Thanks Jim, that's pretty much what I use as well, if I don't have manufacturers recommendations. I have seen instances where the manufacturer recommended lower torque number though, like "torque to 80% of bolt torque values". So was hoping to double check with someone that has a service manual. Guess I should probably just get one for myself.
/ Torque specs for i3040 #4
Being in Alaska, I think a service manual would be a good investment for you.
2024 Ford Transit Box Van, VIN # 1FDRU6ZG8RKB10273 (A65563)
2024 Ford Transit...
LOAD OUT AND SHIPPING (A65563)
LOAD OUT AND...
2018 CATERPILLAR 320GC EXCAVATOR (A65053)
2018 CATERPILLAR...
2250' of 5" Tile (A66408)
2250' of 5" Tile...
2018 Tycrop Vector Belt VB-16H Sand Belt (A64194)
2018 Tycrop Vector...
2007 International 4300 Box Truck, VIN # 1HTMMAAL27H513415 (A65563)
2007 International...
