Hello!
I'm hoping someone can help me with LS recommended torque specs. I had to replace the part that is used to connect the 3PH stabilizer to rear axle. These bolts are also used to secure the ROPS to the rear axle. They are 14mm grade 10.9 bolts, so I'd assume normal torque would be something like 110 lbs-ft. But I'd like to use LS recommendation if they exist.
Thanks in advance!
Thanks in advance!
