Torque Spec for Gator Blades
/ Torque Spec for Gator Blades #1
TractorLarry
I have a set of Gators coming for my 48" Model 317 Deck.
Anyone know the torque spec for these blades on this deck? I would prefer they stay in place :)
-Larry
Cool. And that is.... :)
-Larry
/ Torque Spec for Gator Blades #4
Tight LOL.....
Go to at least 80 ft/lbs, and then there should be no fear of them loosening.
-Fordlords-
/ Torque Spec for Gator Blades #5
When I picked up new blades for my brush hog I asked what kind of torque wrench I should use to get them to the appropriate ft-lbs. The counter guy laughed and said "just tighted the s**t out of them". That exactly what I did and it has worked out fine.
Thanks for the info!
-Larry
/ Torque Spec for Gator Blades #7
However too tight and your crush your bearings - like using air guns at 500 ft lbs
I bought a set of torque wrenches (1/2", 3/8" ft/pound and a 3/8" in/pound) when sears had them on sale, so I'm all set there. I'll probably use the impact to remove the nuts, but never to install them.
Thanks!
-Larry
Ok, I can be silly sometimes.
I forgot that when my sister gave me the tractor, she also gave me a 1" tall stack of documentation including all the manuals (tractor, deck, etc...) purchase receipts, maintenance receipts, etc...
According to the deck manual the proper torque spec is 90-110 ft/lbs.
Pully nut torque is 50-60 ft/lbs.
So, there ya go. RTFM (when you remember you have it) :)
Thanks all!
-Larry
/ Torque Spec for Gator Blades #10
Let us know how the Gators work with your deck. Chances are good you will love them, I think I said before they are a innovative product that work really well for most mower decks.
-Fordlords-
If they do, I'll see if they have one for my 7HP Husqvarna push mower too!
-Larry
-Fordlords-
/ Torque Spec for Gator Blades #12
I have a 1863 Cub Cadet with 54" Deck. I put a set of Gator Blades (3) on it last year..They work great.I don't even get any grass build up under the deck if I cut the lawn when it's wet. I just ordered a set of Gators for my other 1450 Cub Cadet with 44" deck.
Coats 5060AX Rim Clamp (A63689)
Coats 5060AX Rim...
PENDING SELLER CONFIRMATIONS (A59914)
PENDING SELLER...
2022 EZ-GO ELITE...
2021 Peterbilt 389 Sleeper Truck (A62613)
2021 Peterbilt 389...
Tires and Rims (A65640)
Tires and Rims...
New/Unused ATS Grass Proof Cloth (A65583)
New/Unused ATS...
