Torque setting for LK3054 front axle bolts?
   / Torque setting for LK3054 front axle bolts? #1
To20Chris
Platinum Member
Hereford, PA
LK3054
Does anyone know the correct torque setting for the bolts that hold the round housing where the drive shaft comes in to the back of the axle? I'm not sure if this is the front diff or a cover. Two of mine were slightly loose and it was weeping a bit. I'm going to have to order a manual - I meant to do it when I bought the tractor but forgot. /forums/images/graemlins/wink.gif
   / Torque setting for LK3054 front axle bolts? #2
35.4 to 41.2ft lbs. is what the workshop manual calls for.
Thanks! Now I'll have to check and see how well my finely calibrated arm did when I tightened it up!
2020 FREIGHTLINER M2 SERVICE TRUCK (A58214)
2020 FREIGHTLINER...
Bush Hog 72in Rotary Brush Cutter Tractor Attachment (A55852)
Bush Hog 72in...
2019 Toro Z Master 3000 Series 52in Zero Turn Commercial Mower (A56857)
2019 Toro Z Master...
2017 Ford F-550 4x4 Crew Cab Stellar 7628 7,500lb. 3.75 Ton Crane Service Truck (A55973)
2017 Ford F-550...
Honda EM 6500 SX Generator (A55973)
Honda EM 6500 SX...
Yamaha (A55758)
Yamaha (A55758)
