Torque for 7234 and 7235 Engine Bolts
   / Torque for 7234 and 7235 Engine Bolts #1
MajMac392
Southern Maine
Cub Cadet 7234, John Deere X300 Riding Lawn Mower
Several years ago the early Cub Diesels 7234 and 7235 had some problems with bolts that either bolted the engine and transmission together or at the loader mounts, I can't remember which. Does anyone have a picture of the bolt locations and the torque for the bolts? I haven't checked the torque on my bolts in awhile and I can't remember exactly which bolts they are. Every time I have checked my bolts I never found any loose so I haven't checked them in quite some time. Thanks
   / Torque for 7234 and 7235 Engine Bolts #2
There are charts from bolt manufacturers that give torque specks bases on the size and pitch of the bolt.
Roger that ch1ch2, those torque specs for various bolts are in my Maintenance Manual but I hate to break any loose just to get the diameter of the bolt. The metric bolts have a number on the heads but can't that number be for more than one size bolt diameter? I torqued the ones I could get to the other night, I think they had a 17mm head but I wanted to make sure I had the correct bolts.
LOT: Tap & Die Set, Hole Saw Set, Snap Ring Plier Set (A59076)
LOT: Tap & Die...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A55973)
2015 SkyJack SJ86T...
(INOP) CATERPILLAR 914G WHEEL LOADER (A52705)
(INOP) CATERPILLAR...
2020 Chevrolet Silverado 1500 (A55315)
2020 Chevrolet...
500 BBL WHEELED FRAC TANK (A58214)
500 BBL WHEELED...
2016 Ram 5500 Chassis 4x4 ETI ETC37IH 37ft Bucket Truck (A56858)
2016 Ram 5500...
