Toro Zmaster 555 hard to start when cold
   / Toro Zmaster 555 hard to start when cold #1
BeezFun
IL
Kubota B2710
It has a 25hp Kawasaki gas engine, runs great once it starts but starts very hard when cold. Starts fine when hot. I changed plug, that helps a little, but not much. Replaced fuel pump because it had a small leak, that didn't help either. Been this way since I got it new. I use stabil in the gas, run it dry in the winter, stored inside. Any ideas?
tnx
   / Toro Zmaster 555 hard to start when cold #2
Sounds like the chock is not working or needs adjusted
   / Toro Zmaster 555 hard to start when cold #3
x2.... typical Kawi engine... hahahaha.. Had a Kawasaki ATV that the choke would either stick open or full closed..... finally just disconnected the stupid thing and choked it with my hand....
   / Toro Zmaster 555 hard to start when cold #4
could be the valves need adjusting. I have a kawasaki utv and it wouldnt start when cold but once it was going it started fine. Turned out the valves were in need of adjustment. I adjusted them and problem solved.
2007 International 4300 Dump Truck (A51692)
2007 International...
30007 (A53424)
30007 (A53424)
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
UNUSED Clear Corrugated Polycarbonate Roof Panel (A53117)
UNUSED Clear...
7021 (A50322)
7021 (A50322)
