Toro zero turn starter problem
/ Toro zero turn starter problem #1
jmc
Elite Member
SW Indiana
Ford 1920 4x4 (traded in on Kubota). Case 480F TLB w/4 in 1 bucket, 4x4. Gehl CTL60 tracked loader, Kubota L4330 GST
Hello,
My toro zero turn is only two years old and it started just fine last week. Today, when I turn the key, I hear a nice "thunk" near the starter(can't pinpoint its exact location) but the engine doesn't turn a bit. No clicking like a low battery and jumping it changed nothing.
Anyone think it's possible that the starter teeth are not lining up with the flywheel teeth? Still, I can't hear the starter motor turning, so this would only make sense if the bendix drive needs to be extended before the starter turns. If the teeth are misaligned, how can I manually turn the engine slightly since there is no pull cord option that I'm aware of?
I'm going to remove the plugs and hit the starter but I think that's a long shot. Any ideas?
Thanks,
John
/ Toro zero turn starter problem #2
I hate to mention this but what I did once was shut off the tractor while the blades where engaged. When I went to restart it got that clunk noise. After more time and trying this and that than I care to admit there it was right in front of me the pto switch was pulled out and the clunk was the pto every time I turned the key. I thought I'm glad no one was around to see this.
James,
I'm embarrassed to say that it was my PTO switch too! After mowing, I have to turn off the switch to pull into my dusty barn or it looks like a helicopter is running in there. Somehow that switch got pulled up later. Thank you.
John
2018 Ford F-250 4x4 Ext. Cab Pickup Truck (A64194)
2018 Ford F-250...
HARDEE 300 GALLON SPRAYER (A64278)
HARDEE 300 GALLON...
2023 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A64553)
2023 ASV RT-25...
40' High cube 6 door Single use Shipping Container (A64194)
40' High cube 6...
2018 DODGE RAM 5500 FLAT BED TRUCK (A65643)
2018 DODGE RAM...
2007 Ford F-750 Chipper Truck (A64194)
2007 Ford F-750...
