TORO Groundsmaster lift arms are not lowering?
   / TORO Groundsmaster lift arms are not lowering? #1
Deaton
TORO 3280 D
I am trying to switch off the plow for the mower deck on the 3280D. My dad is ill and he used to be a dealer so I should know how to do this...but....
Plow is de-installed, PTO shaft is connected...lift arms will not come down to connect the deck - even with lever in float mode. Is there something I am missing? Switch, bleed valve? I have scoured the entire manual with nothing more than "put lift arms in float mode and weight them to connect mower deck." I weight 180 and they don't budge.
Ideas?
   / TORO Groundsmaster lift arms are not lowering? #2
On my 328D that is similar, I use a small scissor jack to hold the arms down when changing decks:
You might try a short 2x4 to pry it down and some small pieces of wood to hold it down.
Good luck.
YANMAR ViO45-5 EXCAVATOR (A51406)
YANMAR ViO45-5...
2007 Anderson 25ft 7 Ton T/A Flatbed Equipment Trailer (A51692)
2007 Anderson 25ft...
2007 Mack 600 Day Cab Winch Truck (A53117)
2007 Mack 600 Day...
CRAFTSMAN ZERO TURN MOWER (A53843)
CRAFTSMAN ZERO...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
