Toro Goundmaster 72
   / Toro Goundmaster 72 #1
pinebank
My old Groundmaster quit moving the other day after mowing about 5 acres with no problem. The hydrostatic pedal seemed to have no resistance and the machine would not go forward although it would back up slightly...then stop.
I had hoped the linkage fell off, but no luck.
I tryed letting it sit, in case the oil had heated up and the thing would move after it cooled down, but it acted the same.
So now I have the pump out and siting on the bench. Could it be a valve, seems like the pump might not be getting oil. Any suggestions?
   / Toro Goundmaster 72 #2
I think I have the parts and repair manual for this. I may be able to e-mail it as a PDF if you are still having problems.
   / Toro Goundmaster 72 #3
Did you get the pump fixed? I bet it is the print between the two main bodies of the pump assembles. If nothing else send it to Hydro Services in Roland, Iowa.
1997 FORD BOOM TRUCK (A54756)
1997 FORD BOOM...
2018 CATERPILLAR 815K LANDFILL COMPACTOR (A52705)
2018 CATERPILLAR...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2022 Allmond Bros Maxi-Lite II 20kW S/A Towable Light Tower (A52377)
2022 Allmond Bros...
2015 DODGE RAM...
