Toro G3 -- very difficult starting -- suggestions
   / Toro G3 -- very difficult starting -- suggestions #1
Mike_S
South of Kansas City
JD4400HST
Toro G3 with carbureted Kaw 29 hp engine has been very difficult to start from day one -- requires 1-2 minutes constant cranking with full choke when cold in order to get it going, but once started, runs great. I thought after broken in, it would start easier but no way. With new plugs, manual choke visually working right, 200 hrs, fresh ethanol-free fuel with Stabil, new fuel filter, it still takes 1-2 minutes of constant cranking with full choke to start it when cold.
Suggestions/ideas? (needle valve adjustment?? -- dealer is very difficult to work with)
Mike
   / Toro G3 -- very difficult starting -- suggestions #2
Take off the air filter and look into the carb. When you pull the choke, does the plate close completely? If not, adjust the cable so it does. If it is not closing completely, it will not start easily cold.
Polaris ATV (A50324)
2012 UNVERFERTH 15-INCH REAR SPACERS FOR 10 BOLT HUB (A53473)
2012 UNVERFERTH...
2011 Ford F-350 Knapheide Service Truck (A54814)
2011 Ford F-350...
2000 John Deere 1860, 30ft Wide, Gandy Box, Wing Fold, 7.5in Spacing (A53472)
2000 John Deere...
2008 VE 500 BBL FRAC TANK (A53843)
2008 VE 500 BBL...
2018 KENWORTH W900 DAY CAB (A53843)
2018 KENWORTH W900...
