Toro 328d front axle
   / Toro 328d front axle #1
Rudythetank
Toro 328d
Would anyone know what this is/ how to fix this issue?
   / Toro 328d front axle #2
It appears to be a flex coupler, possibly driving a front mounted hydraulic pump..?? Definitely need a new yoke, and flex couple discs. If it was taken apart in the past, looks like the bolt may not have been tightened enough, and allowed to work enough to shear the bolt, and break the flange. Or, too tight, and partially twisted the bolt off, until metal fatigue took its toll, and the bolt broke.
Thanks for the info!
   / Toro 328d front axle #6
The rubber disks are in the transmission drawing:
   / Toro 328d front axle #7
Currently working on the engine to transmission drive coupling assembly on my 1996 Toro 223D. Model 30223 serial 60001-69999 I am having issues figuring out how it's supposed to go together.
I got new rubber couplings 115-4523. I can't get the assembled drive shaft back in the space available.
The installation instructions are kind of vague. No torque specs. For the rubber coupling to drive pulley. Are you supposed to tighten it all the way down until the spacer couplers 125-9249 are tight ? Compressing the rubber coupling?
Any thoughts and advice would be nice. I don't want to get it jammed in there too tight and mess things up.
Thanks.
I posted on this thread as I thought the OP might have a similar issue
2016 Ford F-450 Crew Cab Knapheide Service Truck (A52377)
2016 Ford F-450...
Ford Pickup NR (A50323)
Ford Pickup NR...
2013 GREAT DANE 53FT REEFER TRAILER (A54607)
2013 GREAT DANE...
2018 Toro Workman GTX Electric Utility Cart (A51694)
2018 Toro Workman...
2007 Ford F-750 Chipper Truck (A52377)
2007 Ford F-750...
MISC CABINET PARTS (A54757)
MISC CABINET PARTS...
