Toro 266-H won't Charge
/ Toro 266-H won't Charge #1
Iplayfarmer
Super Member
Idaho
Massey Ferguson 1215, Case 801B
My Toro 266-H won't charge the battery. The battery will take and hold a charge from a plug in charger, but after mowing for a while, none of the electrical components will work (I.e. PTO clutch) and eventually the engine even dies. If do a quick charge on the battery, I can get the machine to fire up again and I can finish mowing.
I checked the voltage accross the battery terminals with the mower running and I'm only getting 11 volts.
How do these things charge? What should I check or replace?
/ Toro 266-H won't Charge #2
I have never had to fix a charging system on any of mine but there is a stator and a charging regulator and I figure either could be bad but would probably try the regulator first.
Get your eng and model #, there is parts places like this one with diagrams to help. Parts and Diagrams for Kohler Engines SV530S-SV530-0003
I've got all the books and manuals that I downloaded from the Toro website. I'm just lazy and was hoping that someone here would have a quick and simple response.
It looks like I'm pouring through manuals, though.
I looked in the Toro demystification guide (great resource, by the way) and found the voltage regulator. I don't have an ammeter that will do 20 amps to test the output from the regulator, but I did find that there's plenty of voltage on the AC side of the regulator and no voltage from the B terminal to ground.
As long as testing the B terminal (the one in the middle) to ground is a good test for if the regulator is putting out voltage is a good test, I've got a bad regulator.
Anyone have any good online sources for small engine parts?
Here's the link to that "Demystification Guide" for Electrical systems. It's a pretty big file (31mb), but there's a great glossary section that goes into some great detail about every electrical component on these mowers. It describes how each component works and how to test it. I would think it's pretty relevant to all mowers, not just Toro.
https://lookup3.toro.com/classes/doGetPub/?pubid=13298
I just thought of something. If the regulator is connected to the battery, shouldn't I at least get the battery's voltage?
/ Toro 266-H won't Charge #7
It should not unless that circuit is running through something else to change the values.
/ Toro 266-H won't Charge #8
If it is a direct line to the battery, you should have battery voltage. A short circuit could blow the fuse and regulator.
You probably have a bad regulator.
I was hoping that wouldn't be the case. I still haven't had time to chase the wire and see if it's good or not.
I got to thinking of something else too... the description said that the regulator needed to see battery voltage in order to work. The only way it could see the voltage is through this wire.
Can you tell I'm really trying to make this into a $0.12 wire problem instead of a $50 regulator problem :)
/ Toro 266-H won't Charge #10
Have you checked the fuse yet. If it is a permanent magnet alternator, it does not need an exciting voltage from the battery. If the alternator is good and the engine is running, there should be voltage. If it has an external regulator, there will be 3 or 4 wires from the alternator to the regulator. If the regulator is built in, the voltage is rectified and regulated and sent out to the battery through a fuse.
This regulator has three wires. Two come from the alternator and put out 28 to 50 Volts AC depending on engine rpm. The other is the regulated DC voltage to charge the battery. I'm getting the AC voltage, so I assume the alternator is made with permanent magnets on the flywheel. The book, however, says that the "regulator...must be connected to the battery to function". See below for the evidence of this.
I haven't checked the fuse yet. There are actually two fuses according to the schematic... One between the regulator and switch and one between the switch and the battery. I'll have to check them next time I get some daylight. The main fuse is working because I get power to everything. I'll check that other one.
I hooked up some jumper wires, though, and I'm sure the regulator is working...
Engine off:
B terminal of regulator to Ground = No voltage
B terminal to battery positive = 12 volts (short to ground)
Engine on:
B terminal to ground = no voltage
Battery positive to ground = 12 volts
Battery positive jumpered to B terminal to ground = 14 volts. (regulator putting out charge voltage.)
Now I just have to chase the short. I still can't figure out how to get the cowl off the engine to chase the wires. Back to the books I suppose.
/ Toro 266-H won't Charge #12
That alternator might not be a permanent magnet alternator for this reason. If it is a regular alternator, it need an exciting voltage to start charging. Once it is up to speed, the regulator begins to regulate the current through the field windings. Usually when you turn the ignition on, it send 12 volts to the alternator as an excitation voltage to get things going. Since you put 12 v to the B terminal, you gave the alternator an excitation to charge at 14.2v DC. There might be a broken or disconnected wire running from the ignition switch back to the regulator. If your alternator is putting out 13v to 14.2v, that means that the alternator and maybe the regulator is good.
I believe tere is a way to get max charge from the alternator, and that is to jump 12v DC to one side of the field .
Alternator Terminal ID's
'S' terminal
Senses battery voltage
'IG' terminal
Ignition switch signal turns regulator ON
'L' terminal
Grounds warning lamp
'B' terminal
Alternator output terminal
'F' terminal
Regulator Full-Field bypass
/ Toro 266-H won't Charge #13
I found a nice signal tracer at Home Depot that does a good job at tracing wires on automobiles, and tractors. First disconnect the battery, and connect the beeper to the wire you want to trace. Then you take the other part of the unit and follow the beep. When you can not detect a beep anymore, the wire is broke or unplugged. If it stops at a fuse, the fuse is probably bad.
I've identified the problems. The symptoms were actually caused by two issues.
There was a short to ground in the fuel shut-off solenoid. I'd already pulled the guts out of the solenoid valve earlier due to another problem, so I just disconnected it. Now there's no more voltage between the positive terminal and the regulator B terminal.
The other problem is that there was some kind of short in the fuse block. The fuses were all good, but when I moved the wires going to the fuse block, the battery warning light on the dash would come on and off.
I couldn't see any obvious wear points or breaks in the wire, so I sprayed a bunch of electrical cleaner in the whole fuse block and blew it out with compressed air. I put the fuses back in and it seems to work now. I ran the mower for a few minutes with the lights on, and the battery warning light never came on. Knowing the nature of electrical shorts, though, I won't be surprised if the problem re-appears. This time I'll know what to look at first.
/ Toro 266-H won't Charge #15
I really don't think you had a short. A fuse would blow or the wires might burn and melt. If you don't have a voltage from the ignition switch to the alternator, it will not charge, and the low battery light will come on. Now if you jump a wire from the battery to the ign terminal on the alternator, it might start charging and the low battery lamp will go out.
/ Toro 266-H won't Charge #16
sounds more like dirty /loose connections.
I guess "short" is actually the wrong term for it. What I had was a loose connection. The fuse box connections for the wires going between the battery and the regulator were not making the connection all the time; and, therefore, I wasn't getting voltage to the regulator so I wasn't getting charge to the battery.
I did have a short going to that fuel solenoid in that I was getting continuity to ground with it. It wasn't a very strong connection; or, like you said, it would have blown something. I did notice previously that if I let the mower sit for a while without starting it, I'd have a low battery. A slow drain due to a weak short would explain that.
2007 Ford F-750 2,000 Gallon Water Truck (A60352)
2007 Ford F-750...
2019 TAKEUCHI TL8 SKID STEER (A60429)
2019 TAKEUCHI TL8...
12" MINI HYD AUGER (A60430)
12" MINI HYD AUGER...
UNUSED FUTURE 72PRO-72" MULCHER (A60432)
UNUSED FUTURE...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A61165)
IMPORTANT PLEASE...
2018 CATERPILLAR 336F L (A58214)
2018 CATERPILLAR...
