Comparison torn between rear blde and box blade
   / torn between rear blde and box blade #1
alflen52
wayland,mi.
new holland 25s
I am going to purchase a 3pt blade for my bx2200,but am torn between a 5 ft. rear blade or a 5ft. box blade,i know the box blade is twich the price,it will be used for snow removal,leveling along a river bank and filling in a wet area.
   / torn between rear blde and box blade #2
Probably the blade is better suited for snow and angled river bank, you would need one that tilts, also one that offsets is very useful for keeping your tractor away from a ditch and will keep you away from the edge of a ditch...
   / torn between rear blde and box blade #3
Well, if you were near me, I would offer you a used box blade (sorry 6 foot, not five). I haven't used it in years, but I am in the market for a rear blade but the costs of the heavy duty Cat II or III ones are cost prohibitive compared to a box blade. If I were in your shoes, a rear blade with removable ends might be a good investment, or so I am told when it comes to working with snow.
David from jax
   / torn between rear blde and box blade #4
Boxblades aren’t fun for snow removal, if going forward they fill up then it’s hard to get all the snow out. If going backwards your neck will be hurting not long after starting. For your uses listed I vote blade first then eventually you can find you a used 5’ box blade and save some money rather than buying a new one.
   / torn between rear blde and box blade #5
The rear blade will be much more universal in use than the box blade. Both require quite a lot of practice to become truly proficient - but everyone starts at ground zero and goes from there.
Two things to acknowledge - with ground engagement implements - weight is definitely your friend and - when you angle your blade to plow - you will automatically loose plowing width.
Example - a 72" rear blade angled at 45 degrees will plow a 50" path - same blade angled at 35 degrees will plow a 60" path.
These widths are approximate because I calculate them on paper.
BTW - box blades have a very definite and good use - unfortunately because they can not be angled - snowplowing is not one of their good uses.
   / torn between rear blde and box blade #6
I'm not sure your BX will pull a 5 ft box blade. That is a lot of weight. Also, box blades don't work at all with wet soil.
   / torn between rear blde and box blade #7
box blades are not the best choice for snow...Also if you do not have hydraulic top and tilt it's another reason to go with the rear blade over a box...although T&T also makes using a rear blade much easier...
Good luck...
   / torn between rear blde and box blade #8
...box blades don't work at all with wet soil.
Not sure what the earth is like there but I won't even attempt to groom an unpaved road or driveway unless there has been a decent rain in the last 24 hours...there is a certain MC where it (gravel/dirt) is so much easier to work with than when overly dry or really muddy...
Working overly dry material tends to separate the fines from coarser gravel...
   / torn between rear blde and box blade #9
I agree, but to drag and infill properly it has to be just right with a box blade...
   / torn between rear blde and box blade #10
My hydraulic angle rear blade was a waste of money as far as I'm concerned. It sits more than it's used. A loader and a box blade are the two most useful attachments you can have. They can do everything. I built and maintain a mile of bushroad with mine.
I use a blower for snow because I am in an area that gets 13 feet of annual snowfall, but one day I tried my box blade on my 300 foot long driveway in about 4 inches of snow and I was quite surprised how well it did. It just kept rolling the snow inside it. Sure some did spill over the top as I went but it worked better than I would have thought. Got to the end, lifted and it all dumped out.
2012 Ford F550 (A55973)
2012 Ford F550...
2008 Ford Ranger Pickup Truck (A54814)
2008 Ford Ranger...
2015 Chevrolet Silverado 3500HD Knapheide Enclosed Service Truck (A56858)
2015 Chevrolet...
Black Steel Diamond Plate (A55758)
Black Steel...
2014 Ford Taurus AWD Sedan (A54815)
2014 Ford Taurus...
Oscillating Tower Fans (A54816)
Oscillating Tower...
