Torn ball joint boot
/ Torn ball joint boot #1
rlee6
Central Florida
Allmand 8435 HST (TYM T330 HST)
The rubber boot of a ball joint is damaged. It is on the front axle and doesn't seem to be too difficult to replace (part may be expensive). If I scrape out the dirt and seal up the area with silicone glue (Permaflex), will I be able to get more hours from it?
/ Torn ball joint boot #2
worked for me, i used automotive "goop" instead of silicone, it seems to grip better. once i put the stuff on i wrapped the joint horizontally with duct tape tight and left it for a couple of days then took the tape off. let it set nice.
mike
/ Torn ball joint boot #3
Don't be cheap. Pop the joint apart and get a new boot. i've seent he rubber parts on the shelf at napa.. cheap insurance..
Soundguy
I wish I had taken a picture of the ball joint. It has a flat top, just like a typical sealed unit. But it also has a grease nipple on the side. My neighbor, who is my coach on almost everything (tractor, plowing, culvert driveway, etc), says it is a sealed joint and I can leave it as is. Does it make sense to anyone?
Soundguy,
I didn't know the rubber boot was a replaceable item. I thought the whole control arm had to be replaced. That's why I wanted to get as much life from it before replacing it. Thanks for the advice.
/ Torn ball joint boot #5
Well.. if must come apart to be attached right? How similar to a tie rod end is it?
If it has a grease fitting.. that tells me it is not a 'never needs service' part..
Doest it have a urethane donut around it?
Soundguy
I've seen rubber boots held by steel bands. On this one I didn't see a band or anything that appears to be removable. I will take a closer look at the boot. In the meantime I will visit a NAPA store for boot and filter cross reference. Thanks.
PS: I don't know what you mean be a urethane doughnut. I didn't notice anything that fits "urethane doughnut" on the ball joint. I will inspect carefully next time.
/ Torn ball joint boot #7
Chris:
Last time I had a urethane donut, it was a Crispy Kreme. /forums/images/graemlins/grin.gif
What exactly is a urethane donut? I don't have a clue unless you mean the spacer washer.
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
2000 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2000 Bobcat 863...
2003 Dodge Ram 4x4 Ext. Cab Pickup Truck (A59230)
2003 Dodge Ram 4x4...
2006 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2006 Ford F-150...
2019 FORD F-150 STX CREW CAB TRUCK (A59823)
2019 FORD F-150...
2025 HD Trailer Solutions EQ15 T/A Equipment Trailer (A59230)
2025 HD Trailer...
